05 Freightliner runs then dies when VCU plugged in.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by sergk1989, Aug 31, 2021.
  1. sergk1989
    sergk1989 Bobtail Member
    39
    10
    Jan 23, 2013
    05 freightliner Columbia with Mercedes engine. The truck will run with the vcu plug disconnected but have no throttle, gauges all out. As soon as plugged in, it dies!!! Is this a vcu problem or something shorting out? Sensor? Already replaced cam and crank sensors
  3. Ross_Tech
    Ross_Tech Light Load Member
    133
    134
    Aug 31, 2021
    Check the wire at pin 1 on the 18 pin connector at the vcu for short to ground. Also check the pin on the VCU itself. It should only be grounded with the idle shutdown timer or engine protection shutdown.
  4. sergk1989
    39
    10
    Jan 23, 2013
    You mean unplug it and run the truck, check the pin inside the vcu?
  5. Ross_Tech
    133
    134
    Aug 31, 2021
    You don't have to run the truck. Just disconnect the 18 pin connector, and check pin 1 on the vcu and see if its grounded. If it is, then it is the VCU telling the engine to shut down. You could verify by removing the pin 1 terminal from the connector, plugging everything else back in and see if it runs normally. But it may be shutting the engine down for a reason. Are there any fault codes?
  6. sergk1989
    39
    10
    Jan 23, 2013
    No, it’s not grounded, but also no wire coming out of the pin 1. The can data wires are shutting down the truck, with them disconnected, the truck runs but without the any gauges and throttle. As soon as one is plugged in, it dies. It’s the pin 13&15 in the 15 connecter
  7. Ross_Tech
    133
    134
    Aug 31, 2021
    Sorry. The schematic I have showed 18 pin connector/pin one in the list, but 18/2 in the drawing. Ill attach it. With the CAN connector disconnected, the VCU cant talk to the engine. It sounds like the VCU is getting an incorrect input to shut the engine down, and does it once the can lines are connected again. The gauges drop out and throttle doesn't work because those are inputs/outputs of the VCU that relays the info to/from the engine.
  8. sergk1989
    39
    10
    Jan 23, 2013
    So am I right thinking the VCU is still good, since no faults? Possible something shorting out?
  9. Ross_Tech
    133
    134
    Aug 31, 2021
    Most likely the VCU is still good if you don't have any faults from any other module. You would have to try a test VCU to verify. Without the truck wiring diagram its hard to say. I would still suspect something with the vehicle power shutdown circuit in the wiring diagram I attached previously. It says "IGN" so I don't know if the VCU is expecting to see 12v on that pin when the engine is running and is shutting down because there's an open circuit.
