05 Intl 9400 CAT c13 won't start
Discussion in 'Trucks [ Eighteen Wheelers ]' started by flatpete77, Sep 21, 2015.
  1. flatpete77
    flatpete77 Bobtail Member
    16
    2005 international 9400. Cat c13. Got home Friday morning and shut truck off like normal. Went out Sunday to leave and its dead, no lights, no clicking, nothing works. Checked all battery connections, fuses on top of batteries, everything good and tight. Called TA road squad; he couldn't figure it out. Batteries will read 15+v then go down to .2v. He was going to jump it but his jumper wasn't working.
  3. 062
    062 Road Train Member
    6,276
    33,782
    Oct 20, 2013
    How did you check voltage? Most won't show 15 volts with motor running.
    Need to check all wiring,battery box,starter,frame grounds.
    Do the headlights work?
  4. flatpete77
    16
  5. flatpete77
    16
    Voltage meter on each battery. Truck won't start so motor isn't running. No headlights, no dome lights, nothing. 13+v to alternator.
  6. 062
    6,276
    33,782
    Oct 20, 2013
    If you have 13 volts at the starter,then you need to check your grounds. If not then trace wires back to battery box.
  7. flatpete77
    16
    I just rechecked voltage. 5 volts on all batteries and 5 at alt. I was trusting the TA guys meter.
  8. 062
    6,276
    33,782
    Oct 20, 2013
    Need to unhook batteries,check each with nothing hooked to it. Probably lost a cell in one. Unfortunately when one goes,it damages the others it's connected to. Best to replace all at same time.
  9. flatpete77
    16
    All are new as of January.
  10. 062
    6,276
    33,782
    Oct 20, 2013
    Did you leave something on to pull batteries down?
    Pulling down to 5 volts will shorten the life of the batteries,if repeated over and over.
  11. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    062 is right. Until you unhook and check the batteries with them isolated from everything else, you're going in circles. You are correct in that they "should be still good" because new last January, but a bad system can still wreck them. Check the voltage on them each, one at a time with them unhooked. That would be the best place to start imo.
