05 isx400 low temp driving...? Thermostat?
Discussion in 'International Forum' started by hd99_fatboy, Nov 26, 2012.
  1. hd99_fatboy
    hd99_fatboy Light Load Member
    124
    5
    Dec 19, 2010
    carmel, ny
    2005 cummins isx 400, started to get hot sittin at idle, ( fan clutch seems to be operating correctly) then wouldn't stay up to operating temp on the road (down to 120*) @65 mph, was about 40 degrees here
    could it be the thermostat?
    I should chage it anyway...
    but will I damage anything running it cold like that? seems to me it would.
    Thanks for some input
  3. snowwy
    snowwy Road Train Member
    20,591
    13,311
    Jul 6, 2009
    i don't think you'll do any damage. but your heater defenitly won't be as hot as it should. and winter is just around the corner.
    don't understand the getting hopt thing while your idling though.
    but probably the first thing to be checking is that your radiator is full. and you've got a good radiator cap that holds pressure and not leaking.
  4. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    Yup thermostat, mines doing this also but at 150* though.
  5. hd99_fatboy
    124
    5
    Dec 19, 2010
    carmel, ny
    right thanks guys appreciate it
  6. hd99_fatboy
    124
    5
    Dec 19, 2010
    carmel, ny
    wow any special procedures to get at this bugger?
    I thought it was gonna be a 123, but maybe not,, looks like I need to get to the housing under the top radiator hose, according to a schematic on quickserve the thermostat is inside there.
    looks like I need to take off the ac compressor and turbo tubes to get to it...
    anything I should look out for going after this thing?
  7. hd99_fatboy
    124
    5
    Dec 19, 2010
    carmel, ny
    so got the thermostat in there, took about 3 hours, had to remove turbo tubes, ac compressor, top rad hose, all the little connectors for same, out with the stat housing, out with the old stat, in with the new, button it all up, add fluids and test run it,.
    so far so good.
    thanks all for the input
