05 Pete 379 - parking brake issue - "bleeds" air if Air Pressure is below 100 PSI
Discussion in 'Peterbilt Forum' started by indy_colts_fan, Aug 10, 2012.
  1. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Newer air tanks use plastic for the line connection into the tank...check this "seal" if it is plastic. Weather, both cold and hot, will effect it's performance and "sealability".
  3. indy_colts_fan
    indy_colts_fan Bobtail Member
    36
    May 5, 2012
    So I was taking to a trucker at the truck stop and he said I could perform some diag on each air brake canister to ensure it's not a bad canister... he said take the service line off each canister and see if there is air leaking from the can... at the same time the parking/tractor brake is released and bleeding air.
    well i attempted this today and not sure i did this right. wondering if someone could verify.
    1. air pressure in tractor at 100psi... released tractor/parking brake... bleed issue occurred.
    2. removed the service line (clearly marked and is the larger hose of the two) from Front Driver canister... nothing comming from the can, but air comming from the hose.
    3. placed service line back on canister.
    4. repeat steps 1-4 for each can... same result..
    i am going to assume, the brake canisters are working properly at this point???
  4. bender
    bender Road Train Member
    2,105
    1,356
    Jul 20, 2010
    Don't Kid Yourself
    There should be no air coming from the hose on that test.
  5. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    Agreed...bad valve at tank!
  6. bender
    2,105
    1,356
    Jul 20, 2010
    Don't Kid Yourself
    First need to confirm no air pressure in the signal line to that valve before condemning the valve.
    VisionLogistics Thanks this.
  7. indy_colts_fan
    36
    May 5, 2012
    Thanks fellas! I will do some additional diag and let you all know
