Ok maybe I'll get more info here
My 05 379 tilt steering is stuc . It will telescope up and down fine but wont til .
So far I've removed and looked at everything. Tried pushing the latch manually incase the lever wasnt contacting it anymore and lubes it with wd 40. Unfortunately it's still not budgin .
So I remove the bottom bolt that hold the mechanism in but can get the top pin out, not sure if its pressed in or not, to tray and get the mechanism out and get a better look.
Anyone ever deal with this, is it a replaceable part or do I need a whole new column?
Here is a picture of the mechanism circled in orange and the top pin location circled in red
Photo by Glenn Robichaux
05 pete 379 tilt steering issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cajuncowboy654, Jun 28, 2019.
mines kind a finicky too. I dont let anyone touch where its at. Set it where you want it and DONT touch it. So i have had it moved before. I had to keep playing with handle and keep rocking wheel back and forth till it would tilt. It eventually unlocks and i get it where i want it. Like i said i dont touch it.
Did you try all that -
yes Ive tried rocking it working the lever also tried unlatching it with a screwdriver. Nothing works.
Guess its stuck where its at for now. -
dam. its the little things that are a pain
That ain't not lie lol.Cam Roberts Thanks this.
