05 Pete trouble
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Garbologist, Sep 14, 2013.
  1. Garbologist
    Garbologist Bobtail Member
    10
    Sep 9, 2013
    I have a 05 Pete with a 475 bsx motor. It shut down yesterday and wont start back up. It will run on starting fluid. All the fuses are good I cant find any broking wires. Also the fuel mileage sucks its getting 4,4.5 mpg. It has 3.55 rears 18 speed trans. I run between 68 to 70 mph.
  3. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    ISX?
    Is the lift pump working?
  4. Garbologist
    10
    Sep 9, 2013
    The fuel pump is push fuel through lines but not firing. Not sure what lift pump is but how can I check it.
  5. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    if you mean BXS Cat Acert, did you get any warning lights? Did it quit suddenly like you turned off the key? Or did it stumble and miss before it died like it was running out of fuel?
  6. Garbologist
    10
    Sep 9, 2013
    No I didnt warning lights it just shut down like turning the key off.
  7. bubbanbrenda
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
  8. Garbologist
    10
    Sep 9, 2013
    Cat motor. Sorry didnt post that
  9. bubbanbrenda
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    When you turn the key on BUT do not start it can you here the ECM and ABS sensors "clicking" doing their prestart checks?
  10. Garbologist
    10
    Sep 9, 2013
    Yes ever thing does its test. There was no code either
  11. Garbologist
    10
    Sep 9, 2013
    Thanks for help truck is at cat will post what was wrong when I find out
