05 Volvo 780 CB radio/linear problem/quirk
Discussion in 'CB Radio Forum' started by cadillacdude1975, Jan 2, 2011.
  1. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    the facts...........05 Volvo 780I tractor, Galaxy Pluto w/ the astatic 636L and astatic echo board, mini monkeymade antenna rated for well over 10k watts, running the mini "grey" coax with a dead key SWR rating of 1.3 to 1 on channel 19. the antenna bracket is stainless steel and is connected to the factory ground strap that the Volvo trucks have for antennas.
    i recently bought a texas star 250 mobile amp, and driving it with 3.5 watts swinging 30 watts is giving me an average PEP of 350 watts or so. the problem that has surfaced is when the amp is turned on, the radio feeds back really bad. i have to turn the mic gain almost to 10 o'clock so it wont squeal. the linear is fed by a main power circuit inside the cab that is direct to the batteries. it blew a 20 amp fuse so i gave it a 25 and its fine for now.
    the radio has a chrome case and is fed to the factory Volvo CB studs. the linear is taped on top of the radio with double sided tape. the linear is grounded to the frame of dash inside of the truck. i also have a ground wire from the side of the linear case to the CB mounting bracket, and a wire from the mounting bracket to the negative power stud. when i can get it to operate fine, i feel current in the mic wire, meaning it is grounding out through my hand. the astatic is one that has the tangle free cord that is made of metal, and it has burned the snot out of me on the leg once and on my hand.
    anyone have any ideas? when it is talking, its walking the dog. none of this started till the amp was installed so it tells me it has to be a grounding issue but i was wanting some suggestions from a few of the people on here as i am sure this has happened before. i would like to think this mess is grounded enough but who knows these days. they are making these big trucks out of fiberglass and plastic these days.
    any input or questions are welcomed. thanks in advance.
    Rob
  3. kd5drx
    kd5drx <strong>Master of Electronic Communications</stron
    485
    102
    Nov 28, 2006
    Some where USA
    I see you said the amp is fed from the battery and you have it grounded to the frame of the dash. Is the dash grounded to the frame? and what type of grounds are you useing. If you are using regular wire coated you mite try using flat braid ground wire and use it to ground every thing to the frame. You definatly have RF feeding back to your Mic and that is whats biting you if RF and those RF burns sure hurt. Your on the right track it is ground related try grounding every thing separate to the frame sometimes if you ground one piece of equipment to another it will cause a Ground loop just keep trying but you are on the right track i believe.
  4. cadillacdude1975
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    i was thinking about just running both straight to the battery box. that is what i have always done with car installs in the past and i never had a problem. and yes the RF burn did not feel good.
  5. FriedTater
    FriedTater Keeper of The Snakes
    2,202
    887
    Mar 25, 2009
    United State of Texas
    Grounding "boxs" any where but the batteries is asking for ECM cool down
    Feed back thru the ex speaker is due to location of said speaker
    Running insulated wire for grounding purposes only compounds RF issues
  6. Carolina Thunder
    Carolina Thunder Medium Load Member
    584
    179
    Jan 28, 2007
    Coeburn V.A.
    OK,good job a chasing this down. 1ST thing to try would be to move your amp somewhere else or put a rubber mat between the amp and the radio,i have had to do this is the past and its helped. 2nd,Throw that screwing metal mike cord in the trash and get the other style,those things are notorious for this problem!
    Make sure that where the antenna is mounted that it is paint free bare metal,no paint at all between the antenna mount and where ever you have it mounted to. You may end up needed to run a larger ground wire from the antenna mount straight to the frame. Because your not getting enough ground the way its set up now. If 8 gauge wire wont do it then your going to need 2 gauge welding wire,i have the same problems with my 387 Pet and the ground is so poor in trucks these days that you just about have to get drastic with your install. If the mike is biting you then its a ground problem for sure. But it also seems to me that with an SWR that low that you are getting all the ground you need,strange. Does your SWR go up when you transmit? If it does then this would also suggest a ground problem.
    It could also be poorly shielded coax causing this as well. Not all coax is the same and you may want to think about some larger RG213 coax. Check this site out to see what i'm talking about. http://www.ve3sqb.com/hamaerials/ocarc/ although i really dont think its a coax problem,but something to think about.
    If you have a grab handle on the side of your cab faring, they make a mount called an Outback mount (goggle it),its meant for 387 Pet's and T-2000's but it may work on your truck as well. They run about $100.00 but those that who use them swear they work great!
    One more thing,if you still have problems out of this you may want to consider having your modulation limiter put back into the radio. Anytime you put an amplifier on a radio that is over modulated to begin with you make it 10 times worse when you add an amp. This is why,allot of times,you have to turn your mike gain back to stop the squeal. Allot of times it wont matter how much ground you have or where your speaker is,you will still squeal if the radio is over modulated. My speaker is right behind my head and i dont squeal no matter what radio i use,but none of mine are over modulated ether. Remember. An amp is not meant to make you louder,only to make you heard further away,but you seem smarter than most so I'm guessing you already know this.
    I wish you luck my friend.I have been fighting the antenna setup on my 387 Pet for over a year and although i have it close,its still not as good as i would like it to be. they just dont make trucks the way they used to!
  7. IDIeselman
    IDIeselman Light Load Member
    173
    59
    Feb 23, 2011
    Ludington on the Lake
    I realise this is sorta old but, How did you make out with your TS 250?
    I just went through the exact same problem with my 500V, Turns out after double checking everything I had to run a secondary ground from the amp case to a body ground. Now it works great with no feedback at all. I have inquired if this is just a band-aid fix to an underlying problem but so far I have not found any definate answers.
  8. rabbiporkchop
    9,676
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
    Who tuned the radio and matched it to the amp? What does the output look like on a scope? What is the phase angle of the feedline? Is the stud an actual 50 ohm stud or is it 30 ohms like most of the truck stop studs?
    Rob[/QUOTE]
  9. cadillacdude1975
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    it turned out to be an RF choke causing the problem. but i dont have that truck anymore so its all good. now i have an international. no problems at all.
