05 VOLVO truck VED D12 engine lacks power and makes 4mpg.. what is wrong?
Discussion in 'Volvo Forum' started by bravoo67, Mar 15, 2012.
  1. Julian1982
    Julian1982 Bobtail Member
    5
    NO IT DOES NOT DROP TO 0 ON THE DASH BOARD, AND HAVE MY EGR's by passed 2 years ago it is not them
  3. russellkanning
    russellkanning Medium Load Member
    640
    142
    Jan 22, 2012
    Frost, TX
    so sad all these similar symptoms and so many tries to fix it :(
    makes me want to hug my D12
  4. marmon96
    marmon96 Light Load Member
    98
    57
    Dec 27, 2013
    gardner,ma.
    did the bozo the clown suit:biggrin_25517: come with the truck when you bought it,i know they came from the factory with them when they were new.maybe you can track one down on e bay the suit when worn will get you the mileage your looking for,good luck
  5. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Let's start from a different angle do u have any kind of codes popping up in the dash besides the egr codes u might have since u bypassed them
  6. Julian1982
    5
    Before they replace injector #4 there was a code for injector 4, now besides the codes for the egr's there is nothing else
  7. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Have they checked if the fuel pressure is Ok or if it's low did t He y hook it up to vcads
  8. v6killer
    v6killer Medium Load Member
    448
    122
    Dec 6, 2010
    ChicagoLand
    The majority of the Problems are the wiring harness for the fuel injector itself not the fuel injector.
    As for the bad fuel milage, do the easy stuff first, check the front mount air intercooler for leaks, got to hold 30 pounds of pressure, only 3 pound drop in 30 seconds, any more then that inter cooler is bad,
    any leaks with the Tubes or the intercooler, can cause up to 2 mpg lost in fuel economy
  9. Hardworker
    Hardworker Light Load Member
    113
    21
    Jun 27, 2012
    Minneapolis, MN
    What was your mpg b4 you replace the inter cooler and how much you gain afterwards also what is your speed everage and weight? Thanks for your sharing
  10. sasha16
    sasha16 Bobtail Member
    5
    4
    May 11, 2015
    Hello !!! PleEASE HELP !!!! I HAVE volvo d13 2011 ,511000 mile, i got a check engine (sa 0 spn 1127 fmi 18) , low power....i replace all fuel injectors, all egr and turbo gaskets, can be the sensor damage ? Thanks
  11. sasha16
    5
    4
    May 11, 2015
    Hello !!! PleEASE HELP !!!! I HAVE volvo d13 2011 ,511000 mile, i got a check engine (sa 0 spn 1127 fmi 18 ) , low power...fuel economy 5 and 6 mpg.i replace all fuel injectors, all egr and turbo gaskets, can be the sensor damage ? Thanks
