'05 Volvo VN780 Fuse(Power Outlet)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AshRae84, Oct 30, 2009.
  1. AshRae84
    AshRae84 Bobtail Member
    Hulbert, OK
    Hopefully you guys can help me, I've searched and searched with no avail.
    The 12V Power Outlet in my sleeper has a blown fuse, and I can't for the life of me find which fuse controls this. It's not listed in the fuse guide (Certainly not under anything related to sleeper 12 volt, or anything remotely close)
    Can you help me find the fuse, or what it's listed under?
    Thanks so much!
    ~*Ash*~
  3. poorrednek
    poorrednek Left Lane Gang
    298
    88
    Oct 23, 2008
    THE DRAFT VA
    Seems like there is a fuse panel in the bunk, but dont hold me to it. I aint drove a Volvo but a little bit.
  4. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Yeah, did you check the fuse panel in the bunk. Its right there with the AC/Fan controls.
    flood Thanks this.
  5. TEN4DISPATCH
    TEN4DISPATCH Bobtail Member
    43
    4
    Aug 14, 2007
    BALTIMORE MD
    I had the same problem with my 06 670 volvo. Check the fuse box in the dash. Its the fuse for 12v overhead outlet. I think its the same outlet for the tv. I don`t know what number it is .Good luck.
  6. galeso
    galeso Bobtail Member
    Try 42 "12V socket cooler sleeper"
    Now if I could just find the fuse for my TV compartment.
  7. Vulcanized
    Vulcanized Bobtail Member
    Fuse panel below bunk heater control - Number 10 - marked "TV/VCR"
  8. Master07
    Master07 Bobtail Member
    SOLUTION!!!!!
    I dont know if you guys already figured out, but this has resolved my issue with 12 v outlet in bank located on top of fridge or on side of this window. FUSE FOR THIS IS LOCATED WHERE ALL FUSES ARE ON THE DASH. THIS FUSE LOCATION IS 42 It is called cooler 12v socket.
    SO FUSE IS NOT IN BUNK FOR THIS ONE IT IS ON THE DASH.
