05'mxs cat chirping noise in front
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bigswede, Jan 30, 2009.
  1. bigswede
    bigswede Light Load Member
    50
    Dec 6, 2008
    have a mxs cat and have always noticed chirping noise and all rpms,checked all pulleys and have replaced tensioners and belts,is this a normal noise for these engines or what should i look for,has cat had any problems with compressors on these engines?
  3. 05379
    05379 Light Load Member
    115
    Nov 15, 2008
    montague ma
    mine makes no chirping at all.
  4. Jas
    Jas Medium Load Member
    Some 6NZ C-15s (same basic gear train as MXS) have an unusual noise from the timing gears but I have never seen one fail because of it. If you pull the fan belts off and start the engine, listen for the noise, if you can still hear it then its an internal noise, if you cant hear it anymore then the noise is from the belts, pulleys, fan, alternator or A/C compressor (or any other driven component you have fitted). A lot of Freightliners out here had early hour Horton bearing failures with the spring applied type Horton so maybe its worth checking the fan drive out. if the noise is internal perhaps take an oil sample and see if there is anything in the sample that may suggest a problem.
  5. bigswede
    50
    Dec 6, 2008
    jas,how would i check the fan,i have a horton on this motor
  6. Jas
    Just pull the belts off and spin the fan, listen for any noise from the bearings.
  7. bigswede
    50
    Dec 6, 2008
    thanks will do,appreciate the info
  8. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    The Horton clutch did nhave a recall or service bulliten on it. They had many of the clutches go bad and take out the radiator, hood, and whatever else got in the way. So basically which it closely and don't wait for it go out. If you can't find the moise, get a mechanics stehascope ( the spellings wron I bet) and you can track it down that way. I check my idler bearings about every 50,000 miles with one just to be safe.
  9. coalhauler625
    coalhauler625 Light Load Member
    96
    12
    Jan 6, 2009
    somewhere in VA,KY or WV
    let me know what ya find mine started same thing yesterday but it sounds more like a rough roar than a chirp , buddies truck started doing same thing too they are both 625 ......im bringing truck home this weekend to put in garage i'll let you guys know if i find anything defeniately in front of motor take belt off check idlers and tensioners, fan hub go from there almost sounds like turbo bearing
  10. lumberhauler_oh
    lumberhauler_oh Bobtail Member
    29
    15
    Aug 25, 2008
    lima ohio
    i had the same noise it was the horton fan hub. replaced it noise all gone
  11. coalhauler625
    96
    12
    Jan 6, 2009
    check your exhaust manifold might be blowed manifold gasket or could be broke turbo stud these twin turbos are nortoris for it my 625 has had the center section replaced twice for this...... just drove my truck home after driver telling me he had a noise sounds like exhaust leak to me i'll pull it in th garage to check it in the morning i'll let you know what i find on mine could even be a broke clamp on one of the bellows
