06 379 pete mxs converison into a 6nz
Discussion in 'Peterbilt Forum' started by travis wal, Oct 17, 2013.
  1. travis wal
    travis wal Bobtail Member
    27
    Aug 29, 2012
    helloo yall , i have a mxs cat engine setting on the shop floor and was wonder if i could get rid of the twin turbo , the engine was in a bit of a fire and needs all new harness and sencers ,and the turbo is laying on a pallet and i really dont no what it is !! somebody told me its been sitting like this for quit a while , and i was wonder how much it would cost to make it a 6nz, with as little money as possable of coures!!i do have a 6nz on the road every day and its been good to me,, thanks yall!!
  3. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    Use the serial # from the 6NZ on the road every day to order an ECM, wiring harness' and on the MXS you will have to move the cam position sensor. Just copy off your 6NZ.You will also need an exhaust manifold, turbo, both oil lines, plugs and plates to seal up second oil line and water line that used to go to the pre-cooler.
    travis wal Thanks this.
  4. Mr.needmeaux
    Mr.needmeaux Bobtail Member
    16
    What has to be pluged off in the mxs head to make it work
