06 9200i help with EGR differential Presure Sensor Location
Discussion in 'International Forum' started by BTR, Aug 2, 2012.
  1. BTR
    BTR Bobtail Member
    4
    Hi everyone,
    i have a 2006 International 9200i, and i had code PID 411
    So i purchased the EGR Differential Pressure Sensor
    im having trouble locating the EGR differential Presure Sensor. I thought i bought the wrong sensor but i didn't called Cummings and they told me it was correct one.
    I have a ISX 435ST engine and i cant find the spot for the sensor. Can someone please help me out please?
  3. Heavyd
    Heavyd Road Train Member
    7,765
    6,204
    Feb 4, 2009
    Here are some pictures. Depending on the type of code, your problem may be carbon plugging in those sensing tubes, so a sensor may not fix your problem.
  4. BTR
    BTR Bobtail Member
    4
    Alright thank you very much, this helps a lot and hopefully the sensor should fix.
