06 9400i Voltmeter
Discussion in 'International Forum' started by Lostkeys, Jul 27, 2013.
  1. Lostkeys
    Lostkeys Heavy Load Member
    903
    6,243
    Jan 8, 2011
    Archbold,OH
    2006 9400i C13 KCB...Voltmeter rarely read correctly while driving. It used to consistently read approx 13.75 V. About three years ago, it started reading low and I thought that the alternator was going bad. So I had it replaced. That helped a little but still wasn't reading what it used to. About 9 mos after that, the truck failed to start one night when I went to leave the house. I found a dead battery. Replaced all 4 batteries. That didn't make any difference.
    While driving I have noticed that if I accelerate hard the gauge will go down to 12 - 12.5 V and when I release the throttle it will go up to 13 V. The gauge usually reads around 12.5 - 13 V now. I have a Voltminder digital display and a Scangauge. Both consistently read approx 13.9 V while driving. Why the difference with the throttle?
    With the key on (engine off) the gauge reads 12.5 and the Voltminder and Scangauge both read 12.1 V...I know, not a big deal.
    With the engine idling the gauge reads about 13 and the Voltminder and Scangauge read 13.9 V.
    On a few occassions the gauge has worked properly and showed about 13.75 V while driving.
    I guess my question is, could a bad battery from years ago have started this? Also, how can it be fixed? I can keep ignoring it (it has been 3 yrs or so) and just use my voltminder, but it has always annoyed me knowing that it used to be more accurate. I understand that the gauge won't read the exact voltage, but it shouldn't be one volt off should it?
  3. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    faulty gauge. or maybe the ecm if that's where the gauge gets its reading from.
    could be bad wiring or schematic board also if trucks have those like cars do.
  4. scottscj7
    scottscj7 Bobtail Member
    20
    8
    Mar 3, 2012
    grand rapids,mi
    I had the same problem on my 9400i the voltmeter reads the voltage the ecm is getting, I had to replace the wiring in the battery box. in the battery box there is a short wire harness with two fuses in it that connect the battery to the ecm. I went to terminal supply and bought new fuse holders,connectors and wire for 18.00 and made a new harness and I have not had problem since and the voltmeter is reading correctly again I hope this helps
  5. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Yep, bad ECM power supply. The volt gauge is actually just feed data from the engine. There is no voltage detection within the gauge itself. Do not replace the gauge. The gauge will drop during acceleration because the ecm is commanding the injector solenoids with a higher duty cycle which requires more power. With a bad power supply the voltage will drop off with higher use. This is not good for electronics. Also, do not forget that good grounds are needed and they should be check too!
  6. Lostkeys
    903
    6,243
    Jan 8, 2011
    Archbold,OH
    Thanks for the replies. I'll look at the wiring. Does the ECM port in the cab read different info from the ECM than the voltmeter gauge would read? I ask because my Scangauge connects to the ecm port in the cab reads a higher voltage than the voltmeter gauge. Thanks again for the help.
  7. Heavyd
    7,826
    6,276
    Feb 4, 2009
    Yes, that 12 volt power comes from the fuse panel, which comes from the main cab supply which comes from the alternator or starter connection.
    Lostkeys Thanks this.
