I wonder if anyone else has hade this problem? This just started this winter. When the temp. is below about 45 degrees outside , my cruise control and Jake brake don't work correctly . The cruise cuts off , and the jake is intermittent . Seems to go away when it warms up outside.
I replaced the Throttle Position Sensor , and the on/off switch for the cruise control , no difference .
Truly puzzled !
06 KW w900 weird problem , Jake and cruise control
Discussion in 'Ask An Owner Operator' started by pawpaw1, Mar 3, 2013.
had it happen to me last year, on mine the brake foot pedal was hanging up got a little snow and dirt under it .
pawpaw1 Thanks this. -
Clutch pedal switch needs adjusted or spring is getting weak.
Had similar problem in the past , found some damaged wires in a plug for the wiring harness , COLD weather make things contract and not get continuity.
I just had a buncha work done. Mainly the jakes. The wiring harness was jacked up. Had them replace it.
When you try to use the jake does it work, then acts like stage one? Then a engine light will come on?
KW900LLast edited: Mar 3, 2013
Your switch is probably fine just bend the arm a little.
