06 KW W900L blower motor issue
Discussion in 'Kenworth Forum' started by trucker1952, Oct 27, 2013.
  1. trucker1952
    trucker1952 Bobtail Member
    Replaced the blower motor but it kicks off med high and high, then kicks back on and will work again.. Anybody have some ideas what the problem could be?? Really appreciate it..
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    reostat could be making breaker kick off, buy at any parts store. ?? not hap.ing before U put in new motor?
  4. puncher
    puncher Medium Load Member
    540
    358
    Feb 12, 2010
    Tn.
    I'm not sure this will be true on your 06, but on the older models there's a harness that has a plug that comes into the heater box on the passengers side and has two screws (I can't remember what it is called) and it has a spring in it that acts like a relay, when it gets hot (weak) it will kick the blower off, not real expensive. I hope this helps.
  5. cumminsISB
    cumminsISB Light Load Member
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    Bad resistor
    puncher Thanks this.
  6. Hellie
    Hellie Bobtail Member
    How difficult is it to replace the blower motor?
  7. Thed302
    Thed302 Light Load Member
    114
    70
    Oct 30, 2014
    USA
    This, all day every day.
  8. Thed302
    114
    70
    Oct 30, 2014
    USA
    Easy as hell.
    Open the hood and go to the P/S. You'll see a black box with A/C lines going into it and the expansion valve mounted directly to it. There's a plate that's held on by four screws that is curved. Take it off and the blower motor will be attached. Unplug the two wires coming off of it (making sure to note which one goes where, you don't want to put it back together and have the fan spin backwards) and remove the motor from the plate. You'll need to remove the squirrel cages as the new motors do not come with them.
  9. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    Mine did that for a couple months. Drove me insane. Changed The fan motor speed controller, then the fan motor. Same problem, ran fine but kicked out after a few seconds on High. In the end it was the A/C clutch relay for defrost. It's in the opposite corner of the panel from the heater breaker so i never found it when looking for hot ones. Replaced that relay and now no probs for 2yrs
    bigguns Thanks this.
