06 Pete Charging System problem
Discussion in 'Peterbilt Forum' started by 379exhd, Sep 14, 2012.
  1. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    Hey all,
    Got a quick question regarding the chargin system on our tractor seems like the alternator's going out on it but not completely sure weather it's the alternator or the gauge. Dad left the sleeper light on all night last week and drained the batteries. Climbed in the next day managed to get it fired up gauge read 14 volts let it idle at 1000 for about 25 minutes to recharge the batteries and shut it off. climbed in it today to run it up to shop out of town to get some welding done on the trailer and only had 12 volts. Had a dump valve wired into the tractor earlier this week but don't think that would have anything to do with an alternator going out. All the battery posts are good all the connections are alright (alternator and battery) but still only have 12 volts. The alternator only has about 20,000 miles on it and it was brand new when it was put on so it's got me scratching my head a little. I'm no mechanic but leaving a sleeper light on all night shouldn't have shorted something least you wouldn't think and wiring a dump valve in shouldn't have caused the problem either. Just wondering if ya'll have any ideas. also it'll hold steady at 12. It was chilly this morning and it cranked a little slow at first but when I came back to pick the trailer up it fired right up so it would appear as though the alternator is still charging i had every light on for 1 1/2 hours on the way up. Any ideas would be helpful.
    thanks
  3. bender
    bender Road Train Member
    2,105
    1,356
    Jul 20, 2010
    Don't Kid Yourself
    Recharging deeply discharged batteries with your alternator can overload the alternators duty cycle by overheating it. When you rely on the alternator to work that hard for an extended period it's best to be going down the road while doing it for the extra air flow to help cool the alternator. When you must recharge while not moving, put your engine fan on manual to help your alternator cool, it will be working beyond it's limits.
    379exhd Thanks this.
  4. 379exhd
    2,925
    3,153
    Jun 25, 2012
    Thanks for the info I'll remember that if it ever happens again.
