06 vnl d.i.d. symbol ??
Discussion in 'Volvo Forum' started by idtwngrls, Jan 30, 2012.
  1. idtwngrls
    idtwngrls Bobtail Member
    6
    maumee, ohio usa
    rollin down the road and i got a stop buzzer and the info display showed a stop sign and a picture of the engine w/ a exclamation point in the middle. after a couple seconds it shut the truck off after gettin to the shoulder i couldnt find anything wrong w/ the truck with fuses, fluids, or loose wires??after a couple minutes i tried to restart and got the same display and it shutdown... finally after a couple more attempts it started and ran fine for another 10 miles then started all over again .... cant find anything in the manual that shows the same symbols and after limping the truck back to the garage (it shut down 5- 6 more times ) the company mechs cant find anything either and have gotten nowhere with the volvo techs either .. anyone have a suggestion
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I have)))) Crankcase pressure sensor.
    Well. use Diagnostic: fault diagnostic: engine menu on dashboard
    idtwngrls Thanks this.
  4. idtwngrls
    6
    maumee, ohio usa
    thanks pablo ill give that a shot and see what happens
  5. idtwngrls
    6
    maumee, ohio usa
    thanks pablo that did it .. fault diag showed undefined fault instead of crankcase sensor but thanks to your suggestion im up and running
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    what is the code in MID 128 PID/PPID/SID/PSID FMI format?
    '06 Volvo... what engine D12D/F ore D13A? D13 was introduced for Euro-V emissions and designed for SCR, but early EPA2007 and Euro-IV engines were available with EGR only, and later with DPF, but no SCR, so old software in dashboards got no text for "new" fault codes.
  7. idtwngrls
    6
    maumee, ohio usa
    not sure. they cleared the code after they fixed the sensor so that they would know if it showed again.. engine ???sorry don't knowi can check on monday
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    so was it the bad crankcase pressure sensor?
  9. idtwngrls
    6
    maumee, ohio usa
    it seems to have fixed it im not having the problem anymore
  10. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    they changed it.
  11. idtwngrls
    6
    maumee, ohio usa
    yup and no problems since
