06 Volvo, all lights work on the truck, to right turn signal on trailer.
Discussion in 'Volvo Forum' started by Aron, Oct 14, 2021.
  1. Aron
    Aron Bobtail Member
    33
    16
    Nov 13, 2016
    Ok so I have an 06 Volvo I don’t know the model as Volvo are slightly confusing with that but vin is 4v4nc9GH06n439504 . All my lights work on truck but have no right turn signal on trailer traced it back and tested at female plug at back of sleeper nothing there either! Already tested all fuses and they are all good power both sides! Somebody help me tell me what I’m missing!
  3. loudtom
    loudtom Road Train Member
    1,717
    2,802
    Aug 26, 2016
    It sounds like the problem could be the wire between the fuse box and the sleeper plug. On mine it looks like a standard green insulated pigtail cord. Try running a new wire from the back of the fuse box to a test light. If it works, you could run a new wire zip tied outside the old sheathing, from the fuse box to the socket under the sleeper. If it doesn't work, I'd look at the pins and connectors next.
    Aron Thanks this.
  4. Daviddank
    Daviddank Bobtail Member
    Did you ever your issue my truck is doing the same exact thinh
  5. loudtom
    1,717
    2,802
    Aug 26, 2016
    It was someone else's issue, so I'm not sure if or how they solved it. Grab a multimeter and start testing for voltage and work towards the signal. Wherever you're not getting voltage from is where the problem should be. If you get adequate voltage all the way to the light, you likely have a bad ground connection or bad light.
