07 9400i losing air pressure randomly at idle
Discussion in 'International Forum' started by Jarheaddriver, Dec 16, 2013.
  1. Jarheaddriver
    Jarheaddriver Light Load Member
    163
    51
    Jan 27, 2008
    Anna, TX
    I have a 9400i with Cummins ISX. While idling the truck will build pressure to 120, purge and remain at 120. randomly the truck loses pressure down to 30 psi in each tank.
    I have been chasing this for a couple of weeks now. No one I take the truck to can find any leaks anywhere.
    Truck off, no audible air leaks, and truck running no audible air leaks.
    Compressor is only 2 years old, air governor is only 1 year old, air dryer is only 4 months old.
    At highway speeds air stays between 100 and 120 psi.
    anyone have any ideas or suggestions.
    Thanks
  3. jbatmick
    jbatmick Road Train Member
    2,198
    2,507
    Dec 1, 2009
    hastings, Fl
    fan air clutch ? check it.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    find out when the PRESS. goes down, stop the truck get out and find leak, air drier might be hanging up sometimes.
  5. Jarheaddriver
    163
    51
    Jan 27, 2008
    Anna, TX
    just replaced fan clutch 3 days ago. still happening
  6. Jarheaddriver
    163
    51
    Jan 27, 2008
    Anna, TX
    tried checking it this way but no audible leaks. what should i check in/on dryer? this started after we replaced the dryer with a brand new one
  7. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    the spitter might be freeze up is heater wire con. getting power? you must catch it acting up and find the prob.
  8. Jarheaddriver
    163
    51
    Jan 27, 2008
    Anna, TX
    spitter? you mean the purge valve, heater wire is connected, i will double check everything again.... please keep giving me ideas, anything helps in this hunt.... thanks.....
  9. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    Air leaks like this with the engine running are common with massive leaks at the turbo actuator or the solenoid valve for the turbo actuator.
    QUALITYTRUCK Thanks this.
  10. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    if you must, you can bypass the dryer to see if leak goes away,
  11. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    if it started when the dryer was changed????????? always look for the common denominator
