07 c13 cranks but want start, odomeater displays ------------------- with key?
Discussion in 'Kenworth Forum' started by peteataustgen, Jan 19, 2014.
  1. peteataustgen
    peteataustgen Bobtail Member
    anyone experience this? assuming is a ecm problem fan light use to stay on till truck was started butnow going out right after key on and it runs through its cheks tach also raises to zero with key on and drops down after check sequence is run as if somehing is lost power?
  3. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    Does the check engine stop engine light come on with the key if it don't flash on might be a bad ecm fuse usually in battery box
    peteataustgen Thanks this.
  4. peteataustgen
    Thanks for your sugestion jameslawton, fuses were good but turns out wire from the 30amp fuse was broke and corroded under the transmison thanks
  5. jameslawton
    257
    65
    May 1, 2013
    Tulsa OK
    Cool glad you found it
