07 freightliner century, loss of power, running hot
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ephy, Oct 12, 2018.
  1. ephy
    ephy Bobtail Member
    22
    7
    Oct 12, 2018
    Auburn
    07 freightliner century loss power also water temperature is always 200+. I’ve changed engine boost sensor
  3. JohnC123
    JohnC123 Light Load Member
    135
    66
    Jan 25, 2018
    Please concentrate on temperature first for obvious reasons or the rest is pointless. Are you adding coolant? Coolant color? Last thermostat? Water pump? Recent engine work/repairs? Fan clutch type? All these things in no particular order are primary considerations that might shed light on some of the other issues your experiencing.
    Rideandrepair and Oldironfan Thank this.
  4. ephy
    ephy Bobtail Member
    22
    7
    Oct 12, 2018
    Auburn
    The water pump bett has more play, it was recently changed
    Rideandrepair Thanks this.
  5. ephy
    ephy Bobtail Member
    22
    7
    Oct 12, 2018
    Auburn
    I meant belt (not bett)
  6. JohnC123
    135
    66
    Jan 25, 2018
    Again, just trying to help you... you say the belt is loose? A proper belt tensioner SHOULD take up any slack as the belt stretches with age. About what temp does your fan engage and THEN shut down? Does your engine piping/tubing show any wet spots all the way up to the cab firewall? A simple radiator cap that has some age on it will allow a "boil-off" to occur. In MY opinion, 200+ degrees is not a normal operating temperature unless your just in from a 12 hour day at the oil patch. Inspect your radiator top and bottom cap seams, most trucks now days have a surge tank mounted atop the radiator and its condition? Is the fan clutch slipping when it engages? As for loss of power, my first question will always be about fuel filter(s).
  7. ephy
    ephy Bobtail Member
    22
    7
    Oct 12, 2018
    Auburn
    And on highway traffic the water temperature rises above 200
  8. JohnC123
    135
    66
    Jan 25, 2018
    Again not sure why your not responding but I wish you the best.
  9. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,543
    May 22, 2017
    Change the thermostats. There are 2 of them.
  10. ephy
    ephy Bobtail Member
    22
    7
    Oct 12, 2018
    Auburn
    Okay I’ll try that.
  11. ephy
    ephy Bobtail Member
    22
    7
    Oct 12, 2018
    Auburn
    What are those 2 thermostat
