07 freightliner century, loss of power, running hot
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ephy, Oct 12, 2018.
  1. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,543
    May 22, 2017
    The 2 thermostats are best to each other at the top of engine. Under the hose.
  3. ephy
    ephy Bobtail Member
    22
    7
    Oct 12, 2018
    Auburn
    Okay thanks. I went under the truck and found out the fuel line splitter was almost loose and moving everywhere and the fitting was leaking.
    Oldironfan Thanks this.
  4. ebill45
    ebill45 Light Load Member
    167
    105
    Oct 11, 2011
    dalton ga
    Air charge cooler
  5. ephy
    ephy Bobtail Member
    22
    7
    Oct 12, 2018
    Auburn
    The boost connector was the problem. And now check engine light came on for baro press sensor. Is it something I should change right away or can it wait until I get to home?
    Rideandrepair Thanks this.
  6. Ruckie
    Ruckie Road Train Member
    1,485
    1,029
    Nov 12, 2011
    Bloom field,nj
    I was driving heard a loud pop now is leaking air no turbo wont go pass 55, when I got to the yard found out my muffler came off and my mechanic cant find the airleak I dont know if one is relates to the other.
  7. Rideandrepair
    17,343
    56,259
    Aug 8, 2015
    It’s probably the hose from air to air cooler to turbo blew out or just was loose and blew off.Muffler was probably already bad Unless just happened? Did you hear muffler noise worsen also ? Or same? Either way fix hose
  8. Rideandrepair
    17,343
    56,259
    Aug 8, 2015
    If it’s not big hose check small air intake hose from intake manifold to air compressor it sometimes is hard to see where it goes to the back of compressor. Often hose fails at compressor connection. Sounds like you’re problem
  9. Rideandrepair
    17,343
    56,259
    Aug 8, 2015
    Check engine light yellow may be stored ( old) code. Red light( active code) needs attention.
  10. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    Driving in heavy snow can cause over temps as the snow plugs off the air to air and radiator.
  11. Ruckie
    1,485
    1,029
    Nov 12, 2011
    Bloom field,nj
    It was my muffler that is clogged it popped and took the air hose with it 100 dollar fix but he told me that my air pressure is too high before the governor kicks in so I should look into replacing the compressor or checking the airlines to see if they are clogged.... also is it legal to run straight pipes... I might or might have not deleted the egr
