07 freightliner century, loss of power, running hot
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ephy, Oct 12, 2018.
  1. Rideandrepair
    17,343
    56,259
    Aug 8, 2015
    Governor on compressor? It can be adjusted or changed. It should kick in just under 100 psi and kick out around 120-125.psi easily adjusted New ones come pre set but often need a little adjustment.Easy fix just change airlines and 2 bolts install plugs in unused ports ( match it up like the old one air fittings and plugs )Stick with Bendix New.$25 Reman $15 are junk from my past experience. EGR info above my pay grade. Good Luck
  3. Youngtrucker91
    Youngtrucker91 Light Load Member
    152
    49
    Aug 11, 2015
    I’m having the same issue with my Detroit 14.0 loosing power at 65 mph loaded and empty
    No check engine light comes
    No misfires
    No rough idle
    Anybody have an idea I’ll help is appreciated
  4. Rideandrepair
    17,343
    56,259
    Aug 8, 2015
    Fuel filters first thing to check
  5. ebill45
    ebill45 Light Load Member
    167
    105
    Oct 11, 2011
    dalton ga
    It’s probably the air governor. Some you can just adjust some you have to replace. It’s cheaper just to run a straight pipe. I don’t know anywhere has a law against them. I run one. Just don’t use your jake breaks going thru town. Might get a ticket for excessive noisy exaust
  6. Youngtrucker91
    152
    49
    Aug 11, 2015
    Problem still not fixed took the mufflers off fuel filter replace started shooting blue smoke but only when lt goes 55-65 mph
  7. ebill45
    167
    105
    Oct 11, 2011
    dalton ga
    Is it throwing a code? Blue smoke is oil burning. In the cyclinders or turbo. Pull the exaust side of the turbo off and run your fingers around the inside of the turbo and see if it feels oily.
  8. Youngtrucker91
    152
    49
    Aug 11, 2015
    No check engine code turbo just replace no oil anywhere to be found
  9. xsetra
    xsetra Road Train Member
    5,115
    6,983
    Aug 21, 2011
    Colorado is the only state I know will give you a ticket ($1,650.00) for not having a muffler if you have engine brakes installed.
    I was only given a verbal warning once in Lamar in 2017. Never was mentioned before in the 10 years I have ran thru Colorado.
    Good luck.
  10. ephy
    ephy Bobtail Member
    22
    7
    Oct 12, 2018
    Auburn
    Truck was running fine but now it just start overheating. Changed temp sensor and thermostat but still the same. Any idea also no heat in the cab.
  11. ephy
    ephy Bobtail Member
    22
    7
    Oct 12, 2018
    Auburn
    Changed the thermostat and temp sensor but truck is overheating
