07 int cummins isx
Discussion in 'International Forum' started by TruckerPete1990, Aug 22, 2015.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,376
    Jul 16, 2012
    Bentonville Arkansas
    Okay so long story short truck has been blowing black smoke and will not stop. Turbo is chafing/Farting.. My fuel is a dark colored like dark blue my fuel filters are turning black. Truck is at a dealer right now i had em run a cut out test on my truck and came back fine. Having turbo checked out monday to see whats going on. They wanna pull my head off and send it out to to be tested. Im not gonna sit in a dealer for them to CHASE a problem down. Them pulling my head will not be cheap. Anyone else have problems with this? ANY input would be great too...
  3. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Get the truck away from that dealer.
    That turbo cough is an egr system issue 99 times out of 100. Did you try unplugging the egr valve?
    When was the last time the egr system was cleaned?
  4. TruckerPete1990
    8,623
    5,376
    Jul 16, 2012
    not sure on last time it was cleaned. and the unplug no i havent
  5. KeithT1967
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Your 07 has a cm870 version of the isx. No dpf, egr valve on the right front of the engine.
    I spent several months debugging an 07 9400 that wasnt quite as bad as you describe but drove me crazy at times. Egr valve was stuck partially open, pretty much every egr passage clogged with soot, and every egr sensor clogged up.
    Knowing what I know now I would start by cleaning every egr passage and replacing all the sensors. Take the egr valve off and verify its functioning. If it is then clean it or rebuild. If not obviously replace.
    I never had black smoke but I can see where a fully open egr could cause it.
  6. TruckerPete1990
    8,623
    5,376
    Jul 16, 2012
    where is the egr value on it?
  7. mhyn
    mhyn Road Train Member
    4,255
    4,512
    Dec 29, 2008
    Northridge, CA
    how about dark fuel? can you explain why fuel is dark? ))) this is not egr valve issue .
  8. taxihacker66
    taxihacker66 Road Train Member
    1,344
    1,224
    Feb 26, 2012
    Concrete jungle.
  9. mhyn
    4,255
    4,512
    Dec 29, 2008
    Northridge, CA
    Dark/dark blue fuel means soot in the fuel. 90% bad injector o-ring, 10 % cracked head. It is easily diagnosable. Run high rpm and with flash light look for bubbles in fuel tanks.
  10. taxihacker66
    1,344
    1,224
    Feb 26, 2012
    Concrete jungle.
    Pete the top picture is the egr valve. It is right behind the water pump on the passenger side.and I agree with mhyn
  11. TruckerPete1990
    8,623
    5,376
    Jul 16, 2012
    there small bubbles in the fuel tank... Does that mean head is cracked?
