07 ISX going through water? no external leaks
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Fullforce, Feb 22, 2012.
  1. Fullforce
    Fullforce Light Load Member
    87
    6
    Feb 2, 2012
    Henderson tn
    Ive got a 07 W900 with a 450hp ISX in it, 600,000 miles
    It is running slightly warm 220-225 and I am having to add about 4 gallons of water every 2,500 miles. It is not leaking any externaly and I can sometimes see what looks like blue/white smoke out the exhaust.
    The truck is running fine so im hoping its not a headgasket.
    Any ideas?
    Thanks
  3. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    EGR Cooler
  4. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    Get it fixed asap. That is a lot of coolant. Don't ignore it & be sure to have the engine oil changed. For longer egr cooler life you should pressure test the cooling system periodically & repair any leaks. You must use a 15 psi radiator cap.
  5. deere
    deere Bobtail Member
    17
    Jan 26, 2012
    Saskatchewan,Canada
    i know of a few people with cracked heads. don't just tell them to replace egr cooler. it would suck if the egr cooler isn't bad but have a cracked head on top of it after spending 2000 on a cooler. egr are famous for leaking but also heads cracking and liners dropping.
  6. Fullforce
    87
    6
    Feb 2, 2012
    Henderson tn
    thanks for the info, Does anyone have a digram of this engine?
    Its my dads truck and I have never messed with these newer ones before with EGR.
    thanks I am going to do a oil test also
  7. Fullforce
    87
    6
    Feb 2, 2012
    Henderson tn
    Also if its the EGR cooler it would be leaking into the exhaust correct?
    I read something were someone said to check the compressor side of the turbo (going to the intake from turbo) for moisture? it might have been a different engine though.
  8. Heavyd
    Heavyd Road Train Member
    7,801
    6,247
    Feb 4, 2009
    Why does everyone think the problem is with the head or head gasket? These engines go through EGR coolers like there is no tomorrow! I have never replace an ISX headgasket just because it was using coolant. The only head I have replaced due to cracking was from an injector bore and fuel was getting into the oil.
    Deere, are you saying he should just skip the EGR cooler and go straight for a head job? I hope you realize that changing a head when it doesn't need it is about 4 times the cost of a cooler job!!! Most coolers can be taken off in under 3 hours. There is a very simple visual inspection and also a pressure test of the cooler. If it were my truck I would have the cooler taken off and tested before even thinking about the head!
  9. Shaggy76
    Shaggy76 Heavy Load Member
    831
    307
    Feb 22, 2012
    Orlando, FL
    On the ISX, the EGR cooler is good for splitting the fins. Fiirst, any coolant in the oil? If not, that eliminates injectors, oil cooler leak, etc. Second, remove the line that goes from the EGR to the intake. Do you see moisture? Also, you can remove a hard intake line between turbo and air cooler. Moisture there? If not, most likely not at intake side of the cooler. It puts it on the exhaust side. Yes, there are 2 sides of the EGR cooler. Now, take a radiator pressure tester and apply it at radiator cap. Start truck and idle it at 1300 - 1500 rpms. Max for the ISX pressure should be at 12 psi. Cap blows at 15. Does the pressure build up past 12 or 15? If so, replace EGR cooler. Exhaust pressure will escape into coolant and in turn force the coolant into the EGR valve or through the combustion chamber. When you replace the EGR cooler, get a radiator cap. That is standard because the pressure popped the cap and the seals will not work properly.
    If the coolant is not building pressure, then the fun really begins. You will need to replace the head gasket. Usually with a head gasket at the mileage you have, it would be rare. Also, these engines have wet sleeves on them and could leak, but again, that is rare on those kind of miles if the coolant filter was changed normally.
    In my professional opinion without looking at the engine, I would guess that the EGR cooler needs to be replaced.
    Fullforce Thanks this.
  10. Fullforce
    87
    6
    Feb 2, 2012
    Henderson tn
    Shaggy it has GOT to be the EGR cooler now that you say it will push exhaust pressure into the water because I have been getting water leaks like crazy the passed month! from a couple hoses, water pump, and the over flow!
    thanks alot!
  11. Fullforce
    87
    6
    Feb 2, 2012
    Henderson tn
    I know I can change it out, but does anyone have a write up on it? Any special tools?
    thanks again everyone this fourm is SOOOOO helpful!
