07 Kw t600 speedometer
Discussion in 'Kenworth Forum' started by Chrisb, Sep 17, 2013.
  1. Chrisb
    Chrisb Bobtail Member
    6
    5
    Sep 17, 2013
    I have a 07 kw t600 the odometer and speedometer stoped working
    i had the speedometer sensor and the gauge cluster replaced with no luck
    any other ideas what the problem could be? Im also getting 31 fault code
    When rpms pass 1400 when driving
    thanks in advance for your help
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Friend of mine has '09 T600 same problem. Found wire harness that runs over trans. had worn through and wires had melted protective coating off. Wires were grounding on top of trans.
  4. Chrisb
    6
    5
    Sep 17, 2013
    Mr Bakerman you were right. It was a wire with the protective cover worn out.
    Thanks for your replay
  5. speedway Trux
    speedway Trux Bobtail Member
    canada
    I have a 2007 T600. The speedometer and the trip meter stopped working after passing on the road with loads of water. Can anyone help how to fix it or what could be the priblem?
  6. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
