I have an 07 pete 379 blows good air defrost and floor but nothing through the dash vents, like the door isn't opening. Any idea how to fix or how much it will cost a shop to fix. Thanks
07 PETE 379 NO AIR THROUGH DASH VENTS
Discussion in 'Peterbilt Forum' started by wildcatexpress7, May 16, 2015.
If I'm not mistaken I think you can go under the dash on the passenger side an get to it. Something is either blocking the flapper or the cable has come loose or is broken. I've had that problem in the past but it's been so long it's hard to remember exactly how I fixed it.
Take the glove box out, there's is an actuator (turns the door) either it's bad or its catching on something
On my 386 if you take the panel off in front of the passenger seat all the HVAC crap is under there. There are 3 actuators that control the blend doors. I would guess one of them was bad. Very easy to do it yourself and very easy to figure out. Take the panel off and fiddle with the A/C heat controls and the one that aint moving is the bad one. Anyway that's how I figured mine out.
Have a 92 379. Defrost and floor blows good. Only the passenger side dash works. Not the drivers. Any ideas?
I can get to all of them and even move the flappers. Unless a flapper is broke off inside. I’ll do some more looking. Thanks
Chubby Fly Thanks this. -
I wonder if its the same for a 2014 Peterbilt 579 MX13.
I changed 2 actuators on the passenger side. I wonder if there is a 3rd on the drivers side?
My problem is my air is NOT blowing thru my front vents....only out the side ones facing the windowsAttached Files:
