07 pete I with c15 cat
Discussion in 'Trucks [ Eighteen Wheelers ]' started by piermechanic38365, Dec 28, 2015.
  1. piermechanic38365
    piermechanic38365 Bobtail Member
    25
    8
    Mar 1, 2014
    Is there a way to pull codes without buying a scanner?
  3. lester
    2,935
    7,940
    Jan 2, 2012
    NW, Iowa
    Yes, something with the cruise control and reading the flash codes. Someone will be along to explain better, or try searching there's plenty of talk about it
    piermechanic38365 Thanks this.
  4. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    With the ignition on, turn the cruise control switch off and hold the set/resume switch in until the check engine light starts to flash. Count the flashes. It will flash a two digit number. ie 5 flashes, a short pause and 5 more flashes would be code 55. it may flash several several codes.
    If it flashed code 55 there is no faults.
    Diesel Dave Thanks this.
  5. piermechanic38365
    25
    8
    Mar 1, 2014
    thanks. i didnt know this. very useful information.
