07 Peterbilt 386 low voltage to fan solenoid
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Con707904, Dec 18, 2025 at 1:57 PM.
  1. Con707904
    Con707904 Bobtail Member
    26
    39
    Apr 30, 2017
    Hey guys, I have a '07 Peterbilt 386 with a C13 and the fan will not shut off. I have confirmed that the fan solenoid functions properly, however the power going to the fan solenoid with the key on engine running is only 2.2 volts. I disconnected the wiring harness on the engine bay side where it goes into the firewall and did not see any corrosion on the pins there, for whatever that's worth. Thanks for any help or direction
  3. Star Rider
    Star Rider Road Train Member
    1,646
    14,625
    Sep 23, 2019
    A/C high pressure switch, Intake Manifold Temp switch.
    Plug it in and see what is commanding it on.
    BoxCarKidd and Con707904 Thank this.
  4. Con707904
    26
    39
    Apr 30, 2017
    If the ECM is telling the fan not to come on shouldn't it have zero volts at the solenoid?
  5. Star Rider
    1,646
    14,625
    Sep 23, 2019
    Without plugging it in you are just going to be guessing and throwing parts at it.
    Trust me on this one.
    Con707904 Thanks this.
