07 sterling truck has a major leak when dash valve is pulled out
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by earnies2, Apr 16, 2019.
  1. earnies2
    earnies2 Medium Load Member
    691
    281
    May 17, 2012
    Dedham, MA.
    2007 sterling boom truck has a major air leak when the air valve on the dash is pulled out to apply the maxies I have a major air leak coming from the distribution valve in the middle of the frame which has the antilock valves on either side. I also noticed it's not evacuating the air out of the cans like it should???
  3. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    It appears the quick release valve isn't working and back feeding to the relay valve and slowly releasing the air to apply the spring brakes I hope my diagnosis is correct
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,435
    6,471
    Aug 26, 2014
    Foot valve sticking?
  5. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    I will check that thanks
  6. BoxCarKidd
    4,435
    6,471
    Aug 26, 2014
    Also wondered about about a hand valve or tractor protection valve issue. Stuff like that can be tough even when you are hands on.
  7. Mr Bob
    Mr Bob Light Load Member
    262
    81
    Mar 17, 2015
    Sorry but your description of whats happening seems confusing. QR valve usually for the parking brake. You may have a bad brake can internal seal. If you have rubber hoses its easy to pinch off each one at the spring brake to see if that locates the source.
  8. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    Update
    I changed out the quick release valve and all is working thanks everyone for your help this site is great
    Art Vandelay Thanks this.
