07 Western Star Lowmax - Left turn signal
Discussion in 'Western Star Forum' started by hpeters, Oct 12, 2022.
  1. hpeters
    hpeters Bobtail Member
    8
    4
    Jul 5, 2022
    I’m having issues with my left turn signal. Right signal works. When 4-way is activated both left and right rear work and only front right. When I have left signal on, nothing works until I use a test light to see if any power is coming to the left turn signal then left will start flashing, only when test light is touching left turn signal wire. Anyone have had similar issue! I have unplugged all harnesses going to front and back of truck and still only right will work.
  3. lester
    2,920
    7,889
    Jan 2, 2012
    NW, Iowa
    Your front left signal is your problem. You said it is the only one that doesn't work when the 4 ways are on correct? Bad light or bad wiring at that light.
  4. hpeters
    8
    4
    Jul 5, 2022
    I will try and replace the light see if it makes a difference. However I did unplug the harness going to the front signal lights and still same issue, right works but not left.
