08 pete with a cummings squeel
Discussion in 'Peterbilt Forum' started by roy stevens, Aug 15, 2012.
  1. roy stevens
    roy stevens Bobtail Member
    I have a 08 pete with a cummings and I get a awful squeel at times. It sounds like its comming from the turbo. I get 7 1/2 to 8 mpg most of the time and I have changed both belts, so I know its not them. Any help would be appreacited. Thks Roy
  3. BigCam9670
    BigCam9670 Medium Load Member
    417
    4,585
    Jun 12, 2012
    Hudson, NY
    It is most likely an exhaust leak. Check to make sure all the exhaust manifold bolts are intact, they are known to break off and then the exhaust manifold gaket leaks. Generally they drill out pretty easily, make sure you replace them all and toque to spec. Also check the bellows around the EGR valve and such. You SHOULD be able to see black streaks which would indicate an exhaust leak and that will be your problem most likely. Good luck
    -Mike
  4. 59BROCKWAY
    59BROCKWAY Light Load Member
    168
    68
    Jun 22, 2012
    Northeast
    If its at the higher end of the rpm's it sounds like your turbo may be on its way out. I always change my oil sooner than later , keeps the bearings rolling a bit better than muddy oil. Think of an oil change like a transfusion. Keeps things cooler. How many miles does the turbo have if it has or has not been replaced yet? Endless variables it could be without looking at it.
  5. roy stevens
    the truck has 270000 on it and I bought it , it had a 100k. It doesn't seem to make a difference what the rpm are, it has happened at idle and 65 mph. I have it serviced about every 15k. Could the oil lines be cloged?
  6. Markvfl
    Markvfl Road Train Member
    1,103
    338
    Nov 29, 2007
    Apopka, FL
    What model truck is it? What trans, rear ratio, tire size? What's your cruising speed? What trailer do you pull?
  7. 59BROCKWAY
    168
    68
    Jun 22, 2012
    Northeast
    270k is still breaking in. =) if the oil lines were clogged it would have seized long ago. I recommend every 12,000 for pm depending on what application you use the truck in , not sure. Is the noise emanating from the turbo? Or is it a loose belt or other? Without the truck being in front of me it's a bit tough to determine. Is it possible to take it to a reliable mechanic? If its a squeel could be possibly the clutch on the a/c too but again endless possibilities. I take it your truck is not a glider and has a DPF motor in it. They can be and are a headache. Doesn't the government know these things need to breath. Too much back pressure if you ask me. But what the heck do I know. It's a big business cleaning them and urea is profitable for the industry.
  8. 59BROCKWAY
    168
    68
    Jun 22, 2012
    Northeast
    I'm not saying your motor uses urea but the newer one do.
  9. Sako3006
    Sako3006 Bobtail Member
    48
    13
    Oct 3, 2011
    Southeast
    2008 Cummins has no urea, but does have a DPF filter. Keep an eye on that EGR Cooler, those motors are know to eat EGR Cooler's about every 100k-150k miles.
  10. driver13
    driver13 Bobtail Member
    alberta, canada
    I was driving an 08 pete 367 up till a month ago, cummins 530, was squealing for about a month and couldnt find any leaks, finally the turbo crapped out. dont know if there is any way to check it out other than a complete dis-assembly. I spent the money and switched to all aftermarket parts, deleted all the egr and dpf, new intake and exaust manifold and turbo. went from avg 3 mpg to 6 mpg, and gained around 75 hp.
  11. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Check the charge air cooler boots for leaks check the back two exhaust ports for broken bolts check the turbo mounting bolts for missing or broken bolts and check the fan and a/c belts an tensoners for wear cracks and tightness cummins always seem to have squeling fan belts also check the fan hub as I have seen them squeling when there on there way out
