Has anyone had problems with Proheat unit shutting down during the night?
last night it ran fine with the tractor idling, I shut off the truck and the proheat cycled 2 times then shut down. Troubleshoot code says its a coolant flow problem. Is there a valve that is controlled by the ignition that is being closed?
If so, where do I find the valve and what is required to fix the problem.
thanks.
'08 Prostar w/ Proheat X-45
Discussion in 'International Forum' started by grocery_guy, Nov 8, 2013.
