09 cummins isx 20 degrees no start without spray
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by myke1175, Dec 16, 2020.
  1. myke1175
    myke1175 Bobtail Member
    11
    Mar 14, 2015
    Hi I have a 09 cummins isx 15 that won't start in the am when outside temp drops to 20 F. or below the fuel water separator has fuel not dry i can't seem to figure out why I changed all filters also after it does start it starts excellent all day until the am now if I keep it starting it throughout the night it will start fine in the am it only fails when its left alone about 6 to 7 hours ..
  3. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    No codes i assume? How fast does it turn over? Have you tried it with the clutch pushed in?
    myke1175 Thanks this.
  4. myke1175
    11
    Mar 14, 2015
    Thank you ....
    its turns pretty normal yes I have with the clutch depressed
  5. myke1175
    11
    Mar 14, 2015
    Thank you ....
  6. myke1175
    11
    Mar 14, 2015
    7d
  7. QUALITYTRUCK
    1,810
    1,773
    Jun 14, 2009
    romulus,mi
    Make sure that your electric fuel pick up pump is coming on. Reach up inside truck and turn key to on position. Step to driver side and listen for sound of electric pump running.
    magoo68 and myke1175 Thank this.
  8. myke1175
    11
    Mar 14, 2015
    Thank you I will in the am ....
  9. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Does it have a working block heater.
  10. myke1175
    11
    Mar 14, 2015
    Thank you yes it does but I have nowhwhere to plug in where I park
