'09 Freightliner, annoying timer to cut off sleeper electrical power
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Metron, Mar 8, 2012.
  1. Metron
    Metron Bobtail Member
    27
    4
    Oct 19, 2011
    USA
    My '09 Freightliner Century has this annoying feature that cuts off all electrical power to the sleeper area. I need light if I'm up. I don't want to be running the engine just to keep my electric on. How do I get around this? Is there a way to defeat the timer? I figure it's about a 5 minute timer.
  3. Everett
    Everett Crusty Shorts, What???
    2,095
    6,401
    Oct 20, 2009
    Hampton,Ia
    in the fuse panel right behind the driver seat on left piller is the fuse box, but beware you pull a fuse for that , you might disable something else, also on the right side under the air bag is a fused box too, just check your manual if you have one , if you need a light , i look at moition lights that runs off batterys.as in most place that sells fire stuff , sell em.
  4. Metron
    27
    4
    Oct 19, 2011
    USA
    Well, I found the fuse panel. But I have no idea where to go from there. I may get myself a led rechargeable "shop" light instead of cutting wires or removing fuses.
  5. fairshake
    fairshake Road Train Member
    1,079
    1,272
    Oct 4, 2010
    Chickenville, BFE
    That is supposed to be a safety feature so you dont drain too much power, mine did this when all 4 of my batteries were going bad. Make sure you have that checked. Now my sleeper power will stay on all night with bunk heater and laptop playing for about a day.
  6. Metron
    27
    4
    Oct 19, 2011
    USA
    Thanks! I'll have it checked.
  7. ITS62
    ITS62 Light Load Member
    164
    69
    Apr 29, 2011
    Gilroy, CA
    My Volvo did this too, but it was a low battery safety shutdown. Turns out I needed new batteries that would keep a full charge and was good to keep the lights on.
