09 Prostar A\C problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by smfry, Jun 26, 2013.
  1. smfry
    smfry Bobtail Member
    18
    Lansing, IL.
    I've replaced the Compressor and High side line to the condenser.. after vacuum and recharge Still not getting very cold, but when I check pressures Low side around 50, High side when compressor is running starts at 150 and SPIKES...
  3. Heavyd
    Heavyd Road Train Member
    7,816
    6,271
    Feb 4, 2009
    Proper charge is 3.0 pounds. You should have lower low side pressure, about 25-30, (depending on hot it is out), but 50 is too high. The high side will quickly rise to 150 and keep rising to about 300 to 350 psi then the fan should kick in. The A/C system on a Prostar is all computer controlled based on the pressure reading and inlet, outlet evaporator temp sensors. If you have a proper charge and the low side is not dropping below 50 I would try an expansion valve.
    smfry Thanks this.
  4. smfry
    18
    Lansing, IL.
    Recovered and Vacuumed (10 minutes) charging 3lbs .. Do I need to ad Oil with the charge?? Charged 3.0 l bs High side still spiking well over 350... and kicking off compressor
  5. BullDoggin
    BullDoggin Light Load Member
    183
    56
    Jan 27, 2013
    I had this issue a few months ago when I put my glider together... now, mind you, the AC is cast aluminum and quite fragile... but I rapped on it with a plastic mallet a few times (SOLID, but not HARSH) while it was running and it cured the problem. Evidently, something inside the compressor was stuck. My old roommate is the head of maintenance for a mid-sized fleet... he said this happens with about 50% of the replacement compressors they get. I focused my "hard taps" on the bolt that holds the lines in the compressor, and the back face near the relief valve.
  6. Heavyd
    7,816
    6,271
    Feb 4, 2009
    Engine fan should be coming on. The body controller is monitoring the pressure. It will tell the engine to turn on the fan at around 300. If the fan isn't coming on, the body controller is cutting off power to the compressor to protect the system. Is the fan coming on at all? As for the oil, technically to know how much to add, you need to know how much is already in the system. This is impossible to know with out removing everything and flushing in. When you recover, if your machine separates oil, I would just put back in whatever amount came out with new oil. System takes PAG oil.
    smfry Thanks this.
  7. smfry
    18
    Lansing, IL.
    Yes the Fan is coming on..
  8. Heavyd
    7,816
    6,271
    Feb 4, 2009
    Ok, the condenser may not be cooling the refrigerant since the pressure is not coming down once the fan kicks in. Make sure the condenser is clean, and not totally plugged with dirt or bugs. The when the system is running and pressure is building take a garden hose and run water over the condenser. If the pressure drops, keep the water on it for a bit and see if the a/c is now cold in the cab. If it is, you need a new condenser.
  9. smfry
    18
    Lansing, IL.
    I'm thinking the dryer is plugged..
  10. BullDoggin
    183
    56
    Jan 27, 2013
  11. Heavyd
    7,816
    6,271
    Feb 4, 2009
    If the dryer/accumulator was plugged the compressor would suck the low side right down to a vacuum. Also, any point in an a/c system that is excessively restricted will behave like an expansion valve and create frost at that point.
    smfry Thanks this.
