1 trailer brake locks up
Discussion in 'Trucks [ Eighteen Wheelers ]' started by chowblower, Nov 18, 2023.
  1. chowblower
    chowblower Bobtail Member
    13
    8
    Nov 18, 2023
    Hi I'm new to the site. I'm having a problem with my 2009 Great Dane trailer. I just had a wheel seal replaced and brake shoes replace on the driver side front axle. brakes worked fine before work got done. Now when I try to stop empty or loaded my wheel locks up that got the work done. I brought it back to the shop they say everything looks fine on it. brought it to another shop same thing. the second shop even went through all my slack adjusters and made sure they were adjusted all the same. Nobody seems to have an answer for me and I've searched online and found nothing for my specific problem. anyone have anything I can try?? right now I'm just stopping as soft as I can so I don't keep messing up my tires.
  3. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,957
    Oct 31, 2023
    If that's the only wheel with new shoes than they can't all be adjusted the same since the wear will be minimal vs the others. The stroke will be very different compared to the older worn shoes. Adjust them yourself. Turn the adjustment nut until the shoe touches the drum then back off 1/2 turn. Do the same for all four wheel ends.
  4. chowblower
    13
    8
    Nov 18, 2023
    that's what they guy at the second shop did for me and it still locks up
  5. '88K100
    '88K100 Road Train Member
    1,493
    3,607
    Aug 23, 2020
    Could be faulty brake valve on trailer had to disconnect the blue line to get brakes to release on forward axle of set of tandems. ACDBDC06-8163-418B-A63F-89F861C72747.jpeg
    Phoenix Heavy Haul and misterG Thank this.
  6. chowblower
    13
    8
    Nov 18, 2023
    my brakes release just fine. whenever I get set to move from my parking space in the yard I even do the simple rollback test to see if my trailer brakes are fully released by pulling slightly forward then letting off the gas to let my truck and trailer roll backward on its own to make sure my brakes are fully released. one thing I'd like to add is that when I go in reverse to park my wheel doesn't lock up. it only does it going forward . it almost seems like its too much air pressure going to just that one wheel when I step on the brakes but I can't see how that's possible. and then not locking up going backwards. I would think it would do it going forward and backwards. I really need to get this figured out before we start getting snow all the time for the winter. maybe faulty brake shoes??
  7. JB7
    JB7 Road Train Member
    1,029
    1,815
    Dec 13, 2022
    Laurel, MD
    "brakes worked fine before work got done." So highly unlikely that it is anything else than what was worked on, meaning not an air problem or anything else.
    There are different friction ratings on brake lining and pads. Possible they used one that is more aggressive than is on the other wheels. Or as you mention a bad/damaged brake shoe. Before pulling the wheel I would 1) grease the slack adjusters and s cams 2) Set the tractor brakes but not the trailer brakes. Have another person apply the trolley valve or foot brake and compare the wheel that locks up to the others. Is it applying at the same rate and releasing like the others? If someone pulls the wheel they should closely check the cam bushings, splines, rollers (maybe wrong ones, actually any part they replaced when doing seal) and drum. If the friction rating of the other shoes on the other 3 wheels is not visible it may end up being better to replace the ones on both sides of that axle.
    Rideandrepair, misterG and Deezl Smoke Thank this.
  8. Iamoverit
    2,159
    4,957
    Oct 31, 2023
    Take it back to the original shop and force them to make it right or refund you. Why are you driving around with bad brakes?
  9. OLDSKOOLERnWV
    19,158
    289,709
    Do the new brakes stay locked up, or do they release with the other 3 brakes as they should?
    New brakes with old brake drum or new brake drum….?
  10. Big Road Skateboard
    7,150
    40,463
    May 2, 2021
    @chowblower Is this trailer air suspension? If so, have you made sure the air bag at that position is inflated?
    How heavy are you loaded normally?
    Rideandrepair and BoxCarKidd Thank this.
  11. Deezl Smoke
    Deezl Smoke Medium Load Member
    540
    356
    Feb 12, 2011
    Hillsboro Oregon
    I agree. Change occurred at the point work/replacements.
    IMO, before the new corner gets any more wear, replace the other 3 corners with the same components. Same brads, part number etc.
    Only other issue could be antilock sensors.
    JB7 Thanks this.
