10 soeed to 13 speed swap... which tranny model?
Discussion in 'International Forum' started by Black_ice_96, May 12, 2019.
  1. Black_ice_96
    Black_ice_96 Bobtail Member
    4
    Hello fellow truckers,
    I have a 96 9300 eagle. 12.7 Detroit 550hp with 3.52 rear gear on 255-70-22.5
    I do long haul. No overweight loads. I cruise 70mph at 1750 rpm. I see guys running 13 speeds 74mph at 1600. My question is I wanna swap my 10 speed to a13 speed. What model 13 speed should I go with?
    Thanks in advanced
    Black_ice
  3. Cattleman84
    Cattleman84 Road Train Member
    9,995
    71,298
    Nov 1, 2017
    The Sticks, Idaho
    I dont know model numbers... But if you can find a "single over-drive 13-speed"... Thats what I would put in my own truck... But they can be tricky to find.
    If you really want a little more speed and dont pull over weight... And got $$ to burn... Put a higher geared rear end in... You really dont need that 3:52 for only 80k.
    Any way you dice it, a tranny... A rear end... Both... Its not going to be cheap, and it will take several years to get your investment back.
    If it were me I'd probably leave it alone and back out of it a little... Unless the tranny or rears took a dump and needed replaced.
  4. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Are you sure about the 255 tires, those are the baby stepdeck tires, rarely seen on a class 8 truck.
    You need to see which model 10 speed you have, some have just as high of a gear as the 13,spd, or close enough to not make a difference.
    magoo68 Thanks this.
  5. Black_ice_96
    4
    I run a 9 car stinger. 255's on drives and trailer
  6. Bean Jr.
    Bean Jr. Road Train Member
    5,539
    9,876
    Mar 30, 2014
    I have an RTLO14613B. I have 3.90 rears and tall 24.5. 1,750 rpms is about 70 mph. This is a single over, .87.
    1,750 rpm is a little high for a 12.7. I'd prefer about 1,600.
  7. Black_ice_96
    4
    Yeah 1600 puts me at 65mph. So your running a taller tire and taller gear. The same tranny wouldn't do much different for me due to smaller tires but my rear gear is lower. Am I better off with a double over drive tranny
  8. RockinChair
    RockinChair Road Train Member
    5,229
    13,502
    Feb 19, 2012
    Lubbock, TX & thereabouts
    Eaton Fuller 13 double-overs usually have 0.86 and 0.73 ratios. From the numbers you've given us, it appears that the transmission you have now also has an 0.73 overdrive, so swapping transmissions would not help you. Because you are limited to your current tire size, your only option for slowing down your RPMs is to go with a lower rear gear. 3.42 would have you running 1600 RPM at 70 MPH and 1700 RPM at 74 MPH.
    Bean Jr. Thanks this.
  9. wore out
    wore out Numbered Classic
    16,638
    203,083
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Couple a different final ratio 10 speeds but by your info you are running a .74 final gear. The 13 you want is a RTLO16913 or a RTLO15713. But they both have a final ratio of .73 that 1 percent difference will not make the rpm difference you are wanting. You will never even notice it. All the 13 is gonna do for you is be closer between gears
    Bean Jr. and RockinChair Thank this.
