10 spd vs 13 spd vs 18spd
Discussion in 'Questions From New Drivers' started by Bill51, Aug 8, 2015.
  1. Bill51
    Bill51 Road Train Member
    1,180
    2,973
    Jul 27, 2015
    All things being equal, you would think the 18 spd would get better mileage than the 13, which would get better mileage than the 10.
    Back in the real world, how's it work out.
    And while we are here, could you show your truck/engine/trans/mpg?
    Thx.
  3. Balakov100
    Balakov100 Road Train Member
    3,937
    2,636
    May 10, 2012
    Temple, TX
    It's not that simple.
    I have a company Cascadia with the DD15 and DT12 Auto.
  4. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Unless you spend a lot of time running around in low range an 18 speed will give the same mileage as a 13. Bot transmissions are simply 9 speeds that can split gears, the 13 does it in high range while an 18 does it in both high and low.
    Both are better than a 10 in otr assuming the driver knows how to drive for mileage in the first place.
    Cummins ISX powered Prostar, 475hp/1750tq, 13 spd
    bwill092 and HeWhoMustNotBeNamed Thank this.
  5. Chinatown
    Chinatown Road Train Member
    73,532
    165,679
    Aug 28, 2011
    Henderson, NV & Orient
    Companies are switching to automatics because they get better fuel milage.
    The tanker company I drove for tested two trucks with automatic transmissions. A Freightliner and a Volvo. They rejected the Freighliner because it kept shutting down due to emission problems.
    I drove the Volvo which had a Volvo engine married to a Volvo automatic transmission; ran 48 states with it and had zero problems.
    The Freightner had a Mercedes-Benz engine and don't know what type transmission.
  6. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    The reason that 10 speeds are speced is because they are harder for drivers to tear up than a 13 or 18. People think that it is because of weight but they are pretty much bullet proof, especially for new drivers. Can you imagine a new driver getting an 18 speed and hitting every gear when they are in front of you? I have only done that a few times but I was also in the 150-160k range.
    Besides, when you are hauling stuff that is bigger than the trailer mileage does not come into play at all.
  7. KeithT1967
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Just disable the range selector. make the noob suffer with a 9 for a while.
    I rarely split gears other than 7th and 8th. Unless I'm climbing Tehachipi with a heavy load.. then I'm usually debating the pros and cons of beating someone senseless for making me drop to 3rd when they miss a gear and stop in the middle of a pull.
  8. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    86 10 speeds they blow, 13 or 18 is the way to go.
  9. RockinChair
    RockinChair Road Train Member
    4,947
    12,344
    Feb 19, 2012
    CC, TX
    If the truck is spec'ed and driven correctly, a 13 speed is a dream come true.
    Even if the truck is underpowered, a 13 speed gives the driver more options than a 10-speed for keeping the engine in the power zone (for climbing hills) and for keeping it in the sweet spot (when cruising on level ground).
  10. PayCheck
    PayCheck Medium Load Member
    634
    359
    Jan 21, 2012
    ca
    I may be wrong but comas are going to automatic because it hard for a driver to tear them up and they get ok milage.
    A 13 speed is the way to go if it's your truck and you don't pre select the gears.
  11. Bill51
    1,180
    2,973
    Jul 27, 2015
