10 speed OD or 13 speed OD
Discussion in 'Ask An Owner Operator' started by Airfolden, Mar 6, 2011.
  1. Airfolden
    Airfolden Bobtail Member
    9
    Feb 28, 2011
    I am deciding between two trucks. One with a 10 speed OD and one with a 13 speed OD. Both in a dd15 Detroit going OTR. Any thoughts?
  3. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,727
    16,492
    Jan 18, 2011
    Would like to help--but need a little more info--what are you hauling(weight-type of trailer)where are you running--who is driving--how much experience do they have? What is the gear ratio w/each truck?
  4. rbht
    rbht Heavy Load Member
    888
    525
    Jan 23, 2010
    CT,NH
    For me if both trucks are in good shape and you would be fine buying either one i would go with the 13spd better resale falue plus a better tranny all around IMO. When pulling a hill you can split the upper gears and maintain speed alot better than with a 10spd.
  5. elpuft
    elpuft Light Load Member
    123
    15
    Oct 9, 2008
    Buckeye, AZ
    I was looking Also To getting A 13 Speed detroit 60 515 Hp hauling Frozen and produce. Hauling From Ca, Yuma AZ to Ap, Ny Area
  6. elpuft
    123
    15
    Oct 9, 2008
    Buckeye, AZ
    Can You explain Split The upper gears ? Never Drove a 13 spd ..
  7. ‘Olhand
    6,727
    16,492
    Jan 18, 2011
    A 13 is basically a 9-where you can split the top gears--shift your bottom four-the do your range split(up to 5th)at this point you basically have 2 gears in each of the top 4
    You do your range split--to the low side of 5th(should be knob--usually red or gray)on side of gear shift handle-back is low side(if right hand is on shifter-put your thumb on the splitter(red/grey knob)if you cannot push the knob back w/thumb--that is low side. OK so now in top side of tranny(5th gear low side)when you are ready to shift next gear--just take your foot off gas and slide that(red/grey)knob forward(that is 5th hi or 6 whatever u wanna call it) Then when you are ready to shift again-shift up(full gearshift move like normal on 8-9-10spd)as the gearshift goes through the neutral position--bring the knob back towards you--continue this until you are in the top side of your top gear--works basically the same in reverse(downshifting)
    Now there are all kinds of variables--and gears u can skip etc. But until you get the hang of it just take your time--use every gear--and you will be fine!
    Just my$.02
  8. 25(2)+2
    18,751
    45,573
    Sep 18, 2006
    the road less travelled
    If the splitter button is gray, it's a 18, if the splitter is red, it's a 13, these drive about the same except you can split any gear including reverse with 18 speeds.
    'olhand Thanks this.
  9. ‘Olhand
    6,727
    16,492
    Jan 18, 2011
    You are 100% correct--as long as nothing has been tampered with--or rebuilt.My current 18 has a red knob(but we rebuilt this truck out of 2 others)so I used both colors--just in case--but that is very good advice--he might actually get into an 18--that someone thought was a 13!
    I thought I was giving him all the variables--but after reading your post I probably should have been more specific!:biggrin_2552:
  10. Airfolden
    9
    Feb 28, 2011
    My driver likes the 13 but 10 speeds are becoming more popular. I am looking for the best fuel milage. Both have a 3.42 gear ratio. Pulling a hopperbottom weighing in 80,000 all the time loaded and sometimes a dry van.
  11. ‘Olhand
    6,727
    16,492
    Jan 18, 2011
    If your driver likes a 13 and YOU feel he is qualified to use it properly--then I would go w/13--it gives you more flexibility--you can get a little better mileage(again used properly) and if you are planning on trading/selling later typically a 13 will be worth alittle more and easier to sell.
    Good Luck to you!
    Just my$.02
