10-Speed Peterbilt 379 - Save Fuel with 13-Speed Upgrade?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by elpuft, Jul 12, 2011.
  1. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    9 speed is best for fuel economy because it prevents drivers to make unnecessary shifts. Every shift spends fuel, engines are made to be lugged down and use the whole rpm range. I see and hear 90% of the drivers using too many gears with 13-18 speeds.
  3. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,487
    Nov 11, 2008
    Sorrento Maine
    If anything change out the 3:70 rear ratio for a long legged ratio, like 3:58. You want something where your turning 1500 rpm and be able to do 65 mph in high gear.
  4. perrykit
    perrykit Bobtail Member
    24
    beaumont mississippi
    some 13 dont have much od like 9s & 10s
  5. lostNfound
    lostNfound Road Train Member
    3,506
    2,269
    Jun 28, 2007
    Home of the Stampede
    From Eaton:
  6. jeffw
    jeffw Bobtail Member
    15
    May 12, 2011
    Bolingbrook, IL
    may save fuel economy with a 9-speed, but from a sales POV, a 13 speed is a better sell when you get ready to dump the truck. The conversion kit is around $2400 or so. Just quoted one the other day.
  7. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    Um....Just because you have 13 choices doesn't mean you have to use them. If you don't split the high gears you have a 9spd but it's nice that they're there when you need them.
    I don't believe that a 9spd is better on fuel. I had one and the jump between some of the gears is so great you find yourself leaving it in a lower gear and running a higher RPM than you would normally.
  8. V8Lenny
    1,016
    130
    Aug 3, 2008
    Europe
    Tell that to most of the drivers, especially those driving Fuller. It's harder to skip shift with non-synchronized box so they go through all the gears to prevent grinding.
  9. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Nothing to skip shifting. Maybe you need more practice...:biggrin_2553:
  10. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    skip shift? WTH are you talking about? Your not skipping anything your just not splitting the gears. A 13 is just a 9spd with a splitter box on the rear, you could just remove the 13spd knob and replace it with a 9 and no one would be able to tell without looking under the truck.
  11. melpromud
    melpromud Medium Load Member
    463
    114
    Jan 29, 2010
    camden ny
    Wrong 13s have the same od as 9s and 10s.
