10 years since SCR technology on trucks
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Oldironfan, Oct 15, 2018.
  1. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,545
    May 22, 2017
    I keep hearing the scr systems are getting better.
    And I admit stainless is better for most parts.
    But I dont think they can improve it much more than it is.
    So that it breaks down less. Or causes less damage to engines from high heat exhaust temps, or to much back pressure causing head issues, or excess heat in the head causing warpage.
    The engines still seem to be not very long lived in general.
    You can change the pistons to forged steel but the egr still pumps soot into the cylinder.
    This is just something I've been thinking about. I do not work on trucks.
    Rideandrepair Thanks this.
  3. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,474
    6,907
    Oct 22, 2016
    North Dakota, Eh?
    The company I work for has about 25 trucks, and the few he has that rolled over 1 million without an overhaul have a DD15. The couple trucks with Cummins, needless to say, didnt even make 500k. One DD13 blew a football sized hole in the block.
    Rideandrepair and Oldironfan Thank this.
  4. Oldironfan
    5,776
    5,545
    May 22, 2017
    I mean with extensive scr maintenance it's possible.
    But the earnings vs cost of operation do not make any sense.
    And DEF is expensive in the USA.
    Rideandrepair and Crude Truckin' Thank this.
  5. skellr
    skellr Road Train Member
    8,735
    12,188
    Jul 17, 2011
    The Village, Portmeirion
    The DD13 has a carbon block with metal liners...
    Crude Truckin' Thanks this.
  6. Oldironfan
    5,776
    5,545
    May 22, 2017
    Dont you mean Graphite iron block?
  7. skellr
    8,735
    12,188
    Jul 17, 2011
    FL called it "Carbon". Maybe th y didn't want to confuse people. :)
    Sales has thier own ideas I'm sure.
    Oldironfan Thanks this.
  8. Oldironfan
    5,776
    5,545
    May 22, 2017
    There is not many advances to be had for block material design I think. Unless carbon fiber or something would to be used.
    A high nickel block would be good I think like the last of the Ford 302 blocks.
    And they key now is saving weight even on blocks I think.
    Also I believe common rail injection is a big factor in reliability being poor in modern diesels.
  9. Crude Truckin'
    2,474
    6,907
    Oct 22, 2016
    North Dakota, Eh?
    Ahh maybe explains it.
  10. Misesian
    Misesian Road Train Member
    2,078
    3,178
    May 21, 2014
    Nothwest Arkansas
    I’ve owned 2 Cummins and the soot in those was a big problem. I be talked with a Cummins salesman and he didn’t convince me they solved the soot problem.
    I’m driving a new International with the A26 and I’ve been very impressed. Today I had itin for the over head at 121k miles and the inside is super clean. Whatever they did seems to have worked in keeping soot down. International has said they have greatly reduced EGR flow into the motor via increased combustion efficiency. I can attest, after today, that is true.
    Going forward with EPA phase 2 regulations in 2021,24, and 27 I think it will only get better. I can’t soeak for other motors but, the GHG17 A26 is doing fantastic.
  11. Oldironfan
    5,776
    5,545
    May 22, 2017
    Probably thanks to VW.
