10spd trans lost in the gears
Discussion in 'Questions From New Drivers' started by rjp1983, May 12, 2010.
  1. rjp1983
    rjp1983 Bobtail Member
    morris county nj
    Hi all,
    I am having a bit of trouble here. I do not have an issue with shifting or double clutching, however, when it comes to downshifting, I get a little lost as to where I am in the gears. I dont know if its the fact that I am starting out in second gear and dont remember that. I am used to a 5spd car. I am ok from 2 to 5, hit the splitter, and am good at 6, but going higher then downshifting i get lost as to where I am. Does this make any sense? I dont really know how to explain it. Anyone have any tips or tricks for remembering where you are in the gearing?
    Thanks
  3. red_eye
    red_eye Medium Load Member
    430
    122
    Dec 30, 2009
    belpre, ohio
    10=45+ 9=40 8=30 7=25 6=20 5=15 4=10mph ..as a general rule....make sense?
  4. Saddle Tramp
    Saddle Tramp Medium Load Member
    590
    235
    Jul 13, 2009
    laurel, nebraska
    :biggrin_2558:Just remember that there are 5 low gears & 5 high.
    When you split from low to high put the shifter in the same gears that you did on the low side. 1/6 toward you & down, 2/7 neutral then over a little then up, 3/8
    streight down, 4/9 all the way over than up, 5/10 streight down. By looking at the stick you should be able to see what gear you are in. It takes practice,it will come to you.:biggrin_25514:
    When down shifting just reverse the process, it takes practice, be patient.
  5. Allow Me.
    10,679
    12,240
    May 28, 2009
    Rancho Mirage, Ca.
    Don't think you need to downshift from 10 to 9 to 8 to 7 etc. Why beat yourself up? You only need to downshift when slowing for a turn or if the light turns green suddenly as you are approaching a red. You can leave it in gear from top speed down to almost a complete stop. The Ca. DMV says you only need to downshift 2 times during the road test, and that's one gear, not all 10.
  6. Skunk_Truck_2590
    Skunk_Truck_2590 Road Train Member
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    Down shifting with the jake brake on. Gotta love it.
  7. rjp1983
    morris county nj
    guys, sorry for the long wait on the response. been very busy. with all the tips yall gave it has helped alot. I really do appreciate the help. Now to work on dialing in the alley docking.
  8. Saddle Tramp
    590
    235
    Jul 13, 2009
    laurel, nebraska
    how about trying to up shift with the jake on.:biggrin_2559:sometimes i forget i have it on.:biggrin_25514:
