Some are programed to read half, 3/4 or full. It's all up to the hacker who does it and how good they are
11 Michigan men charged in major U.S. diesel engine tampering case
Discussion in 'Ask An Owner Operator' started by Tarh331_Dad, Apr 28, 2023.
Page 6 of 6
We'd update everything that had a laptop plugged into it if it was outdated. Takes about 10-15 minutes to update it. Not a big deal to start the process and let it update while you're setting up to do the repair.
Siinman Thanks this. -
I just have a custom program running on the ECM that tunes the engine much better, since the factory settings dont work with a lot of my aftermarket stuff like custom injectors, larger turbo, timeing ect. and the factory program causes it to run real rough and start to smoke and backfire from running so rich. Ive put do not update ECM on the work order and they do that to "spite me" for a "delete" and then i gotta pull my ecm and send it off to be fixed AGAIN which runs around $4500. And yes i did end up forceing the shops to pay for it since it wasnt a delete just a custom tune.
That said this is why i keep waffleing on putting a cat in my pete dispite being legal and costing vastly less then new garbage. i get the feeling "wonderful" people like good or cat here would intentionally #### with it even if the repower is perfectly legal and shown on the paperwork.
Oh and also a good delete by someone who knows what they are doing leaves the little def needle working fine. Or in some cases has a second ECM that is not deleted and is set up to act like everything is normal and accepts updates. -
Now when you check your truck in you sign a sheet saying your emission system is intact and that you’re aware they will hook up to the ECM. -
Simple fix carry extra ECM swap it out before you take it to the shop.
Page 6 of 6
