12.7 Detroit 60 Cant find coolant temp sensor
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Peterbiltt, Jan 4, 2018.
  1. Peterbiltt
    Peterbiltt Light Load Member
    230
    85
    Aug 21, 2014
    Ontario Canada
    Have a 98 Peterbilt 377 with a Detroit series 60. I called multiple dealers and spent 30mins at a Freightliner dealership trying to get the same sensor shown in the picture (middle and right one). They give me one that has a 2pin like a clip in, they say that's but mine off the vin but mine is like that. what do i have to do? Get the one there giving me and retrofit basically? Did Detroit update the sensors? i got mine a few years shown in the pic
  3. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    Ok, there more than one coolant temp sensor used in your engine. One sensor, the two wire connector type, is the sensor the ECM uses. The other one with the single stud is for your coolant temp gauge. Make sure you specify what you need when you call them. They probably don't know or have forget about separate temp sensors for the gauge.
  4. Peterbiltt
    230
    85
    Aug 21, 2014
    Ontario Canada
    The two i need are on the ones that are in the middle and right side. Have tried enough, will take them out to get a part number but ive called many dealers havent had any luck
  5. Dave_in_AZ
    371,624
    Take them out and wonder on down to a salvage yard or two, and see if you can make a deal until you can get new ones.
    Michael H and Peterbiltt Thank this.
  6. jamespmack
    213,845
    Have a pete dealer look it up to the vin. I recall being in this situation. One is coolant temp for gauge, one is for ecm, and one is for a/c, fan control. Man its been along time but I think pete is the only one that used it.
  7. Heavyd
    7,751
    6,184
    Feb 4, 2009
    The third one is probably for just the coolant temp high warning light in the dash.
    Peterbiltt Thanks this.
  8. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    If it's for the gauge in the dash, the sender is most likely Peterbilt # 17-02791. The high temp alarm/light sender should be Peterbilt # 05-13721-220.
    They are not Detroit parts, so you need to tell them what it's for to get the correct one. If all you're telling them is a temperature sending unit for a Detroit, you'll get the one on the far left. You need to tell them that it's on the OEM side, gauge or warning light.
  9. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Gotta go to Pete. Oem sensors, got nothing to do with detroit
    Heavyd and Peterbiltt Thank this.
  10. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
    One's for your ECM. (The one on the Left)
    One's for your Gauge, &
    One's for your Horton fan Clutch..
    EDIT: if my foggy old brain cells are working..LOL
    the one in the Middle is your Horton Sender, It should have the Temp setting Stamped on It of What Temp the Horton will kick in. The Gauge one should also have some Numbers ect Stamped on It Too.
    Any self respecting Parts Guy should be able to sort It Out for you..
  11. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    One way to be sure, I see the metal wire tags still on it from Pete. Those stamped #'s would tell him exactly where those wires go. The wiring is the same as a 379 (with the exception of slightly different headlight wiring).
    http://www.supermiller.com/pdf/sk25762.pdf
    Peterbiltt and haycarter Thank this.
