12.7 Detroit leaking oil from blow by tube
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Killinmiles93, Oct 1, 2018.
  1. Killinmiles93
    Killinmiles93 Bobtail Member
    24
    9
    Dec 13, 2017
    Motor is leaking oil from blow by tube and inlet for blow by tube along with a new oil leak from valve cover on front portion of valve cover to the middle section on passenger side, please help!
  3. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,543
    May 22, 2017
    Check the crank breather filter. Under the valve cover for plugged up, or tube for restriction.
    Otherwise engine is tired.
    Mississippi129 and Killinmiles93 Thank this.
  4. Killinmiles93
    24
    9
    Dec 13, 2017
    Any way it could be coming from air compressor or turbo?
  5. Oldironfan
    5,777
    5,543
    May 22, 2017
    That I have heard. Are you using oil a lot?
    Killinmiles93 Thanks this.
  6. Killinmiles93
    24
    9
    Dec 13, 2017
    No it’s not consuming any oil I’m right at my interval to get an oil change (10000) miles and it’s a hair below the full line, which is from the oil leak.
  7. Killinmiles93
    24
    9
    Dec 13, 2017
    Can the extra crank case pressure from what ever it is that’s causing it, damage the motor? I’m 300 miles from the nearest freightliner dealer with a dyno so I can do a blow by test and weed out what it is
    Oldironfan Thanks this.
  8. sealevel
    sealevel Road Train Member
    2,664
    10,282
    May 31, 2012
    U.S. 41
    Fix your valve cover leak when you have the time. Detroit's love to smoke through the tube. Your oil consumption is near zero especially with the newer oils. If it ain't broke don't fix it.
  9. Killinmiles93
    24
    9
    Dec 13, 2017
    The valve cover leak is due to excessive crank case pressure, trying to narrow down why. And I know they like to smoke but it’s blowing oil threw the tube along with the smoke . Believe me I don’t want to have to fix anything that’s not needing of it but I also don’t want every gasket on my motor to leak because of the abnormal pressure
    sealevel Thanks this.
  10. sealevel
    2,664
    10,282
    May 31, 2012
    U.S. 41
    Man, don't go to Freightliner. Where are you?Maybe some members here could hook you up with a good local shop.
