12.7 Detroit Mechanic
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jasonar15, Apr 24, 2021.
  1. Jasonar15
    Jasonar15 Medium Load Member
    669
    519
    Aug 6, 2017
    I live in North Carolina. I’m needing my 12.7 Detroit rebuilt. Any suggestions on a mechanic around North Carolina and idea of a cost?
  3. AModelCat
    161,631
    Suggest asking your chosen mechanic for a quote. There's dozens of different ways to rebuild an engine that will affect the overall cost.
  4. Jasonar15
    669
    519
    Aug 6, 2017
    I did receive a quote from my usual mechanic. But he seems to don’t need my business from his price. So I am looking elsewhere.
    Bean Jr. Thanks this.
  5. nikmirbre
    nikmirbre Road Train Member
    5,554
    10,210
    Jul 27, 2011
    High Point NC
    I know a guy in Greensboro that rebuilds them frequently....
    baha Thanks this.
  6. Jasonar15
    669
    519
    Aug 6, 2017
    What’s his name or business name?
    nikmirbre Thanks this.
  7. wore out
    wore out Numbered Classic
    16,752
    204,973
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Cheaper isn’t always better. If you have a usual mechanic and know he does good work I wouldn’t chance it. Lots a guys can take a motor apart, a few more can get it together and make it run. Very few can do it right......
    tommymonza, peterd, kwswan and 6 others Thank this.
  8. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
  9. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Most of those old engines are going to need a bull gear for overhaul and more than likely to have the block cut (liner protrusion). If your engine has over a million miles on it and never had a bull gear I would not even warranty it if you did not put in a bull gear. Also if you want to save future down time it would probably be best to remove the rear cover (on the front of engine) while you have the bull gear out and replace o-ring and apply new sealant. If you want an overhaul that is going to last and be done right you are probably looking at around 16K+ on a Detroit (not including turbo or injectors). If you want it cheap then you can probably get it done for 8K or less. High demand and low workforce is going to raise shop prices.
    RubyEagle and QUALITYTRUCK Thank this.
  10. nikmirbre
    5,554
    10,210
    Jul 27, 2011
    High Point NC
    Ill have it to you by the end of today.....
  11. nikmirbre
    5,554
    10,210
    Jul 27, 2011
    High Point NC
