Is it possible to rebuild a 12.7 with rotating assembly parts from a 14 liter Detroit? The truck I'm in right now is a rental and it's finally put me off all emissions ######## with the bad EGR cooler that's putting me at risk of limp mode should the DPF get plugged up enough, and this has reminded me of my desire to build a 14 liter without emissions and won't get me ####ed by the feds at first glance. So is this possible? Would I just need a good crank and an in-frame kit for a 14 liter? Or would I need everything else from a head for a 14 liter to the oil pump? What turbo and injectors would I need for 700 horse? The truck I'm eyeing is a 13 speed, would it be worth my time, the extra size, and weight to go to an 18 while the engine is down given I do refrigerated and dry van work? Thanks in advance
12.7 Detroit rebuild questions
Discussion in 'Western Star Forum' started by Eric Strongbear, May 1, 2022.
Last question for now. Is it worth the time and effort to swap to air disc brakes all the way around on the truck at the same time?
I don't know about the engine, but the stopping power of disks compared to drums is unbelievable.
I also know you can get suspension parts cheap cheap like the birdy goes at the salvage yards that will work just fine. -
My thought as for the engine is because it's a wet sleeve design it should be possible because I don't see why Detroit would have used different blocks or different dimensions for the 11.1, 12.7, and 14.0 because of cost and other issues. If I mess with the suspension I'm going to get a shop to do so because while I trust that I can do it with cars and pickups I'd rather not risk it with a semi because of the magnitude of the consequences, and that'd probably be the new Hendrickson fab'd steer axle and air ride combo. As for disc brakes, I figure if I'm gonna be doing all this I may as well go with new components and so I'd do the Bendix setup
My disks are awesome. They're a snap to change the pads and just a few hundred bucks.
If let them wear into the rotors, you'll be into it for thousands. -
There's a couple threads on here about that. From what I remember a 14L crank won't fit a 12.7L block. Counterweights or something don't clear.
@benjamin260_6 knows these engines in and out. -
That's a bummer. Is there any noticeable longevity sacrifice at the higher horsepower range? Eg, would a million mile engine be reduced to 3/4 of a million? Is there any difference in Jake's between regular duty and heavy haul duty variants like there is with the 3406B Cat?
There are a few wide block 12.7s out there that are the same as the 14L but most won't allow the crank to turn once the rods are installed. To make a ddec 4 14L, I've found it's easier to build a ddec 5 with a 4 head and ecm. You have to get an adapter made for the cam but that's no big deal.
spsauerland and AModelCat Thank this.
