12.7 detroit series 60----looks like i have fuel in my engine oil
Discussion in 'Ask An Owner Operator' started by jvillarreal82, Dec 19, 2018.
  1. jvillarreal82
    jvillarreal82 Bobtail Member
    14
    14
    Dec 19, 2018
    Have any of u guys experience this before
    Smells like strong odor of diesel not burning correctly sometimes when driving
    Also my oil psi is low and dipstick level is higher than normal........change oil 3 weeks ago
    Please help me
    Rideandrepair Thanks this.
  3. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    How many miles on your engine?
    Anything new parts you put on in the last year?
    What truck?
    Are you at home?
  4. jvillarreal82
    14
    14
    Dec 19, 2018
    2001 freightliner columbia
    Bought truck about 5 months ago
    Mileage says it has around 680000 but from the previous owner i know that is wrong....He had about 6 years...Didnt had that issue before.
    can it be a faulty injector causing the problem ?
  5. jvillarreal82
    14
    14
    Dec 19, 2018
    Yes im at home i work locally
  6. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Can you afford to park it for a couple off days?
    Diesel in oil....i don't have to tell you what that does to a engine.
    As to the cause.....there are guys on here who know the series 60 real good but they are sleeping now.
    Rideandrepair and jvillarreal82 Thank this.
  7. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,023
    Jun 17, 2018
    I’ve got 3 trucks over 1.9 million miles with the series 60 Detroit 12.7. I’m no mechanic but I believe one of the main reasons diesel goes into the oil is when you idle at very low rpms in cold weather. You need to bump the rpms a tiny bit. Otherwise all the diesel won’t get burned up and will leak through the sleeve which is not a cheap fix. I could be wrong though because it’s also usually an injector. But with the cold weather it’s something to think about.
  8. Bean Jr.
    Bean Jr. Road Train Member
    5,518
    9,826
    Mar 30, 2014
    YES! Just happened to me. I had scheduled to get unto Detroit and get it checked out. I don't idle so that wasn't the problem. It shut down on the highway. I checked to see if coolant or oil, and the oil on the stick was about 3 inches above the line. All injectors were bad, but number 4 plunger was stuck open. It needed bearings too.
    Get it checked out pronto!
  9. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Check & see if one of your injectors is leaking. I had that problem fixed & the green monster was ready to run strong again. I hope all goes well for you.
  10. jvillarreal82
    14
    14
    Dec 19, 2018
    Thank u all for information.....Will need to check out the truck soon and specially the injectors....Will let u guys know the problem and results so it can help others too
    Rideandrepair and daf105paccar Thank this.
  11. kemosabi49
    10,746
    46,265
    Jan 13, 2013
    SW Arkansas
    Don't keep running it with diluted oil.
    jvillarreal82 and Bean Jr. Thank this.
