12.7 detroit series 60----looks like i have fuel in my engine oil
Discussion in 'Ask An Owner Operator' started by jvillarreal82, Dec 19, 2018.
  1. Spyro2112
    Spyro2112 Medium Load Member
    604
    416
    Mar 17, 2018
    Injector cup is leaking crack head, head gasket, run run far
    Rideandrepair Thanks this.
  3. Espressolane
    17,739
    109,115
    Sounds like a good reason to open up the
    Freightliner Emergency Repair Kit.
    Sounds like injectors are going bad.
    Rideandrepair and jvillarreal82 Thank this.
  4. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    If your going to run this truck at all I would drop the oil and add two gallons of Lucas oil stabilizer to it. Might help prevent any more damage till you get it fixed.
  5. jvillarreal82
    jvillarreal82 Bobtail Member
    14
    14
    Dec 19, 2018
    Thank all of u , truck is at the shop
    Should know by tomorrow noon the issue and will let u guys know
  6. jvillarreal82
    14
    14
    Dec 19, 2018
    are u talking about the main bearings and connectings rod bearings ? Ty
    Bean Jr. and Rideandrepair Thank this.
  7. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Yes that what he is talking about. When buying a used truck it is a good thing to change the bearings so you can know what you're dealing with from the start
  8. Rideandrepair
    17,358
    56,319
    Aug 8, 2015
    I had Injector selinoid leaking on mine. Fuel is oil only thinner. Should be fine. Ran mine till it shut down . Had 10 gallons of fuel added to oil in 60 miles!! Thought I had just blown injector as in the past. Anyway common problem all’s really needed is 1 new. Or buy a six pack for same price as 5. Mines still going good after 1.5 yrs. and mine has over a mil on OH.
  9. jvillarreal82
    14
    14
    Dec 19, 2018
    So ur saying u had only 1 injector gone bad.....did u also have diesel fuel in motor oil.........i know my engine oil level is about 2 inches higher than normal , low oil psi and engine oil looks diluted...Running at 40 plus miles psi at 30 .......No overheating or anything like that
  10. Rideandrepair
    17,358
    56,319
    Aug 8, 2015
    Oh yeah I had 10 gallons of diesel on top of 10 gallons of oil. Only permanent damage was rear main leak got worse. Front main seeps ever since. I ran about 10 miles changed fuel filter same problem, decided to make a run home ran 63 more miles and it shut down. I figured it was a bad injector. As it was running rough. Didn’t think about it leaking into oil like that.Exact same engine as yours. The plastic selinoid on top of injector was squirting a lot of fuel. That might be your problem especially if it was running rough.You didn’t mention that though. Could just have a minor leak. Sometimes the little screws on selinoid come loose, usually they break. I bet 1 screw is broken off 1 injector selinoid causing minor leaking.Ofcourse it could be a bunch of other things I’m sure.Let Us know either way. Always looking for potential future problems.I only changed the one injector. Had 1 go bad a few yrs back also. That time it was just a bad o- ring causing excessive fuel into cylinder.Cost for Dealer to install 6 pack was $3000. Decided to wait and apply $$ at OH. Old Detroit still running good. They can take some abuse. I doubt the bearings are damaged ( maybe a little more worn ).I don’t know what you’re mileage is or OH or? Mines currently got 1.3 mil + on an OH. I really can’t believe it myself. I’ve never pushed 1 this far.
  11. 77fib77
    77fib77 Road Train Member
    10,871
    69,303
    Jul 7, 2010
    St Louis
    It's 700 for an injector. Or 12k for a rebuild. Use your brain. I know you put it in the shop. Hopefully it's cheap.
    Bean Jr. Thanks this.
